Originally posted by Rondec If photography is the way you make a living then it is a need, same as a hammer for a carpenter. Even there, few photographers are able to charge thousands of dollars for a photo shoot and are getting by with a couple hundred for a photo shoot or maybe 2000 for a wedding. In that situation, you aren't going to buy top end gear, even if you can put it on "expenses."
OK, that accounts for about 2% of camera users, most of whom would probably be better off working as waiters.
---------- Post added 01-25-18 at 10:13 AM ----------
Originally posted by angerdan Pentax is a huge systems which allows to use even 645/6x7 lenses on APS-C/35mm bodys.
Number of current available Lenses with AF for 24x36mm image circle is about 100 (including third party models).
How many 6x7 lenses are available new these days?
As an aside, I did own a fairly complete 6x7 system at one time, including the K-mount adapter. Yes it worked, but it wasn't much fun due to the size of the lenses compared to the bodies.
Using third party lenses as an attempt to justify that Pentax has (at the moment) a full system doesn't fly. They aren't Pentax lenses, therefore aren't part of a Pentax system. Third party support can be very capricious, as we found out when most of the third party manufacturers stopped making lenses in Pentax mount for a while. Of course, first party support can also be rather capricious, as we are finding out at the moment.
Also, there is much more to a system than a few lenses. Look at the Canon or Nikon accessory catalogue sometime.
---------- Post added 01-25-18 at 10:16 AM ----------
Originally posted by BigMackCam That very much depends on what the OP wants from the system. Many owners are getting a huge amount of enjoyment and truly excellent results from the K-1 and the available lenses, of which there are enough to deal with most situations more than admirably. More new lenses are needed, I don't disagree... but there's enough to choose from already.
With respect, Bill, Pentax may not be the droid you are looking for, but it seems kind of presumptuous to assume the OP's needs are the same as yours.
Pentax is a system too, Bill - you just don't seem to like it very much these days, looking at a number of your recent posts. That's a shame, but - might I suggest - easily remedied.
The K-1 is an excellent camera body - if its strengths suit the individual's wants and use cases. And the range of lenses is more than up to handling a wide range of tasks very well indeed. Again, they may not meet the high demands you place on them, but so many of our members are getting outstanding results from both the K-1 and available lenses...
The OP asked about a "system". If a body and a zoom lens is all you want, then you don't have the need for a system to supply that desire.
As I mentioned in another post, sorry to disappoint you, but with a stable of over 60 Pentax lenses, and a raft of other accessories (purchased when Pentax was a "system"), I'm not going anywhere.
