02-05-2018, 09:49 PM   #1
Pentax buffer help
Hey all,
I need assistance. I'll be at Kennedy Space Center tomorrow for the Falcon Heavy first launch attempt. When I took photos last week of another rocket launch, and did an engagement shoot this weekend (which was my first real time taking lots of burst shots) I noticed that the buffer very quickly filled on the K1, and my camera was basically out of action until it caught up. Unfortunately, for this launch, I really need to have the camera taking as many pics as I can, especially in the first few seconds.
I shoot with dual cards, with the image being written to both cards at the same time for backup purposes. I shoot only Raw (no jpg). I believe I have error detection turned off. Are there any other settings/things I should do to maximize the number of shots i can take before I'm out of gas?
Thanks in advance!
02-05-2018, 10:27 PM   #2
QuoteOriginally posted by motorhead9999 Quote
The most important thing would be to write to one card only, as other otherwise your writing time / lockout is more than doubled, and you lose about 3 frames of buffer in raw mode. You could also opt for for JPEG for a buffer size close to 100 (80 in backup mode), rather than in the teens.
Or, you can switch to crop mode and stay in raw, in which case your buffer will be close to 50 shots (36 in backup mode).
Personally, I'd either switch to JPEG or shoot crop raws in order to keep the camera responsive. Better to sacrifice a little bit of image quality to capture the right moment
02-06-2018, 12:03 AM   #3
joergens.mi's Avatar
Do you need maximum Frame rate? Maybe medium frame-rate will be enough for that purpose.
Do you need autofocus?
If you need maximum speed, focus and switch to manual mode, to increase speed (i think the object will be in infinity)
Think about using jpg in maximum resolution and quality to have more shoots in the buffer, switch all math off, like ca correction, lens correction, ... (this will increase speed)
02-06-2018, 05:35 AM   #4
Alright, so I switched to single card use and crop mode, and i think this should work. Bonus of crop is that i should get a bit tighter with my view as well.
Here's hoping!
buffer, camera, cards, dslr, full frame, full-frame, k-1, k1, launch, pentax buffer, pentax k-1, shots, time
Buffer Write Speed Question Best Memory Card Settings Larrymc Pentax DSLR Discussion 5 12-02-2017 01:52 PM
K-3 II full buffer and no writing to card! tduell Pentax K-3 11 08-24-2016 02:50 PM
Tip if buffer slows down Shanti Pentax K-1 18 05-31-2016 05:39 AM
K1 buffer fills up quick it seems Shanti Pentax K-1 17 05-21-2016 04:17 AM
Help me pentax k20d 21fps buffer illimited? MISTER_MORRISS Pentax News and Rumors 7 05-12-2008 05:13 AM
All times are GMT -7. The time now is 01:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
