Originally posted by Tas Ok, here we go.
I remind you that after adjusting the in-camera settings (increasing the "clarity" to +4 and lowering the "contrast" to 0), the look of the JPG images improved drastically.
These attachments only serve to show the resolution (detail) coming from the lenses on these two cameras:
- Fixed 28mm equiv. Nikkor prime on the Nikon Coolpix A
- 24-70mm Pentax zoom on the K1
- 35mm Zeiss prime on the K1
I do have dozens of test shots and I took what I saw amongst the best samples from every lens.
My final conclusion is that the 28mm equiv. Nikkor lens on the Coolpix A matches (and possibly outresolves) the resolution of its 16 Mp sensor. The 24-70mm Pentax zoom lens don't quite match the resolution of K1's 36 Mp sensor, being even behind of the Nikkor (it offers less detail). Finally, the 35mm Zeiss prime clearly outresolves the Pentax zoom lens, extracting much more detail resolution from K1's sensor.
The Nikkor is a killer, but the Coolpix camera is limited to 16 Mp.
The 24-70 does not deliver the required resolution for such sensor, it falls behind (it is a zoom ok, but it delivers less detail than the Nikkor!).
Finally the Zeiss is on line with the K1's resolution, delivering as much detail as it can.
---------- Post added 02-25-18 at 03:27 AM ----------
All cropped images from out of camera JPGs (at finest quality) without any post processing.
I named each photo with the camera model (Nikon Coolpix A or Pentax K1) and mentioning which lens on the K1 samples.
---------- Post added 02-25-18 at 04:15 AM ----------
The Coolpix A was shot at its fixed focal length (28mm equiv.)
The K1 + Pentax 24-70 was shot at 35mm focal length.
The K1 + Zeiss Distagon 35 was shot at its fixed focal length (35mm).
