Originally posted by bdery I know you don't like the Godox system,
I'm not sure why you think you "
know" that.
It is most certainly not true that I dislike the Godox system as a rule.
It has aspects that I have critical opinions of, but it also has very good aspects.
Originally posted by bdery but earlier in the conversation, people mentioned using an array of flashes at 1/128
Sure, and that's a perfectly valid point.
Reducing flash power to obtain faster recycling rates is a valid technique and is worth passing on as a tip.
Claiming that a different type of battery is the solution, is not a valid point and invites being challenged.
There are AA-powered battery flashes that recycle within 1.9s from a full power shot. Are you saying that the 0.11s, the V850 with its Li-Ion battery is faster than that is making any practical difference?
At 1/8 power, I wouldn't expect any significant difference between quickly recycling speedlights, independently of the battery type they are using.
Originally posted by bdery At or below 1/8 power, a Godox V850 can keep up with a K-3 firing at 8 images per second.
If you had said, "
you can shoot much longer with an Li-Ion battery" or "
changing one Li-Ion battery is way more convenient than changing four AA batteries", I wouldn't have challenged you. But you made a questionable claim about the battery type being a significant factor in terms of recycling speed. This may have been true when speedlights like the Canon 540 EZ took about 6s to recycle with AA batteries, but it is no longer a valid point nowadays.
