03-24-2018, 02:32 PM   #1
K1 Memory Card slot options
Iíve just updated to Firmware 1.43 from 1.42. Prior to that, I had 1.40 & 1.30. Somewhere along the way I missed 1.42 which I think gave added options for memory card slot options. Up until now I have been running slot 1 for RAW & slot 2 for JPG, and now want to switch to sequential use where slot 1 loads followed by slot 2 when 1 is full. Existing 128mb cards are partially full. The user manual has a picture showing an arrow to slot 1 filling first, but when I set up as required, the menu on my K1 shows the reverse & indeed, this is the case when I shoot. For the life of me I can not work out how to have slot 1 load before 2. Any ideas anyone? Thanks in advance.
03-24-2018, 02:47 PM - 1 Like   #2
Hmm... with only the slot 1 card inserted, turn on the camera, then off. Insert slot 2 card.
03-24-2018, 03:52 PM   #3
Brilliant, that works. Thank you, youíre a champion.
03-24-2018, 05:06 PM   #4
Not a Number's Avatar
The firmware updates are accumulative so there is no need to install previous versions.
03-25-2018, 02:53 AM   #5
Paul the Sunman's Avatar
This is an oldie but a goodie.
card, dslr, full frame, full-frame, k-1, k1, k1 memory card, memory, memory card slot, options, pentax k-1, slot
On K1, the card slot 1 is grayed out when choosing how to write to each slot. Why? duogl Pentax Camera and Field Accessories 5 03-29-2019 04:25 AM
K1 - SD Card Slot #2 defect DimC Repairs and Warranty Service 6 01-24-2018 01:24 PM
SanDisk memory card works on PC but says 'memory card error' in K-S2 kudzx Pentax K-S1 & K-S2 9 02-15-2017 09:03 AM
K1 suddenly has "memory card error" w Sony SD card Syb Troubleshooting and Beginner Help 26 09-12-2016 04:13 PM
tight K-7 memory card slot, SOLVED !!! Pentaxor Pentax DSLR Discussion 3 09-28-2009 10:41 PM
All times are GMT -7. The time now is 05:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
