Show Printable Version 17 Likes Search this Thread
04-13-2018, 12:50 PM - 1 Like   #16
Not a Number's Avatar
They are calling it "Dynamic Shift Resolution System" on the English version K-1 series Special Site, dropping the "Pixel". From what I can make out the Japanese version translates to "Hand Held Real Resolution System"
Challengers | PENTAX K-1 Special site | RICOH IMAGING
PENTAX’s unlimited creativity was the key to realizing handheld photography using the Dynamic Shift Resolution System newly incorporated in the PENTAX K-1 Mark II.
04-13-2018, 01:31 PM   #17
monochrome's Avatar
DSR / DSRS English Acronyms? (Better than HHPS)
04-13-2018, 01:47 PM   #18
Steve - The use of flash should be possible since apparently each frame of the four-frame DPS is treated separately. You are locked out of flash with the original PS but should not be with DPS. Supposition on my part since I do not have a K-1 Mk2.
04-13-2018, 03:10 PM   #19
QuoteOriginally posted by Medex Quote
Why you think that dPS is improved version of superresolution? Short test in dpreview shows that dPS in terms of resolution is not better than 1 picture made in electronic shutter mode. Normal PS gives better resolution (so, it could be named "super resolution).
Based on what is on the site right now, the dPS image does seem significantly better than the regular electronic shutter shot. I don't know if there was a problem before and it has since been corrected.
Pentax K-1 II's hand-held 'Dynamic' Pixel Shift mode is not quite what you think it is: Digital Photography Review
04-13-2018, 03:18 PM   #20
Otis Memorial Pentaxian
QuoteOriginally posted by jbinpg Quote
Should is not the same as does.
Some have long felt that flash "should" be possible for regular pixel shift, but it ain't. I guess, it depends on whether the burst allows time for the flash to recharge. A close analogy to dPS is in-camera HDR. For that feature, flash is disabled if a digital protocol flash is detected. However, X-sync will fire if a digital protocol flash is not detected and shutter speed is within range for X-sync. I won't rule out flash support in dPS, but suspect that it may be accidental as with HDR.
04-13-2018, 03:29 PM   #21
photoptimist's Avatar
Some have long felt that flash "should" be possible for regular pixel shift, but it ain't. I guess, it depends on whether the burst allows time for the flash to recharge. Part of the requirement for "super resolution" is very short time span start to finish for the burst. If it does support flash, that would be cool, but I would not lay money on it one way or the other.
In theory, flash could be permitted but the power would need to be limited to 1/8th max. In practice, even small variations in the output levels (even a 1/10th of stop variation) would create artifacts in the brighter parts of the image.
04-13-2018, 04:45 PM - 2 Likes   #22
It also allows those togs who would like to use flash with Dynamic Pixel Shift to do so. Limited use case but at least it is possible now.
Hey, now! Hadn't thought of that....love it!
---------- Post added 04-13-18 at 07:48 PM ----------
QuoteOriginally posted by LensBeginner Quote
A DPR editor admitting he's wrong about Pentax... how quaint!
I just suffered a stroke.
04-14-2018, 12:32 AM - 2 Likes   #23
clackers's Avatar
Poor Rishi...he has done this before and probably hates Pentax product assignments.
And seems to screw up constantly.
04-14-2018, 11:25 AM - 1 Like   #24
Class A's Avatar
Well, I successfully used flash in combination with Pixel Shift.
I cheated a bit by choosing long shutter speeds and a dark room so that I could manually trigger the flash four times.
However, the same approach can be automated and then supports faster shutter speeds.
The problem is that (IIRC) the camera does not provide four trigger events.
Nevertheless, with radio triggers or flashes that support a delay function (configurable in milliseconds) you can set up four flashes that fire one after another (with their delays aligned with the timing of the four Pixel Shift exposures). Using four flashes also addresses the recycling time challenge, i.e., you could use this approach to fire four full power flashes in sequence.
As photoptmist stated, one needs to pay attention to maintaining exactly the same exposure so one would have to find some way to align four flashes so that they all provide the same exposure. Using a diffuser or a bouncing technique and/or flashes supporting 1/10 exposure adjustments should address this. I understand that RawTherapee can already account for small exposure variations between frames, so when using such a refined post-processing approach, perfectly matched exposures won't be necessary.
04-14-2018, 11:46 AM - 2 Likes   #25
Rawtherapee has a feature that evens our exposure differences across pixelshift frames. Just a note for you flashers.
04-14-2018, 12:40 PM   #26
I suppose we need to wait until somebody confirms if the new DPS allows a flash trigger signal for each frame.
04-14-2018, 03:29 PM - 3 Likes   #27
Tested. Dynamic Pixel shift aka handheld = 4 frames, 4 flashes fired. So yes. Possible.
flash was in manual mode. x sync does NOT allow for pixelshift of any kind. it's greyed out. camera was also in manual mode
04-15-2018, 01:29 AM   #28
Class A's Avatar
QuoteOriginally posted by CNunez Quote
Cool, thanks for testing!
Note that this would support yet another approach to achieve full power flashes without having recycling times get in the way. A radio trigger that supports "group cycling" can be configured to fire a different flash each time it receives a trigger signal. Cycling through four groups would give one four times full power at any shutter speed. Gear-intensive, yes, but neat to have the option.
04-15-2018, 01:59 AM   #29
Wouldn't four different flashes throw four different shadows?
04-15-2018, 03:08 AM   #30
Class A's Avatar
QuoteOriginally posted by Gimbal Quote
Yes, you'd have to make sure that the light coming from the flashes is essentially indistinguishable from another.
For instance, using a four-way flash bracket you could fire all four flashes towards the centre of an umbrella. If you then additionally bounce the output of the umbrella, I don't think it would matter anymore which of the four flashes fired.
dslr, full frame, full-frame, k-1, k-1 ii, k1, pentax k-1, pixel, pixel shift
K1/Samyang 24mm Tilt/Shift and Pixel Shift DDoram Pentax K-1 & K-1 II 6 12-14-2021 06:47 PM
K1ii's "Dynamic Pixel Shift" Will Put A Premium On Small High-Quality Lenses Fenwoodian Pentax K-1 & K-1 II 36 03-06-2018 01:39 PM
SR II on K-1 MKII will offer Dynamic (handheld) Pixel Shift Resolution alpheios Pentax News and Rumors 84 02-22-2018 02:21 PM
Pentax K-1's Pixel Shift challenges medium-format dynamic range Winder Pentax K-1 & K-1 II 22 05-10-2016 08:05 AM
Am I first to see this one: Pentax K-1's Pixel Shift challenges medium-format dynamic bxf Pentax K-1 & K-1 II 1 05-09-2016 02:55 PM
All times are GMT -7. The time now is 03:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
