Originally posted by Ian Stuart Forsyth After looking at the Raw file I can see that any detail above a certain size has some NR done to it in the iso 800 shot I would even say that there is some sharping being done to smaller detail also in that iso 800 shot.
I think everyone commenting on RAW files should specify which converter they are using and whether they checked that the default settings for various ISO settings are the same. In the case of ACR (Adobe Camera RAW, which is used in both Photoshop and Lightroom) there are likely manipulations going on under the hood, i.e., there will be some processing even if the sliders indicate a neutral setting.
Having looked at the RAW conversions presented, I'd say this discussion is one of "splitting hairs" (can't argue with that can you?
The differences are rather subtle and it isn't at all clear to me that the low ISO shots are preferable. They show more colour artifacts and have quite a "digital" look about them with some hairs not being fully connected. If given the choice between the pushed low ISO image and the high ISO image, I'd say the high ISO image would be a better basis to start from.
On the one hand, I'm a proponent of a "hands off" approach to RAW data out of camera. On the other hand, I don't think there is any consumer camera that doesn't massage the RAW data in one way or another to make it look more presentable. In that light, one would have to have very little worries in the world in order to view the nature of the K-1 II's RAW images as a problem. To justify respective criticism, in my opinion, there would have to be a demonstration that files that haven't been "tampered" with allow a better result. So unless someone shows how they can use a K-1 plus respective RAW converter settings to produce a result that is superior to the K-1 II's output, I don't even see as much as a breeze in a tea cup.
