Show Printable Version 17 Likes Search this Thread
05-07-2018, 07:40 AM - 1 Like   #1
i_trax's Avatar
K-1 ii - upgrade?
Pentax K-1 II Review: Worth the upgrade?: Digital Photography Review
I am not going to upgrade, although DPR was always hard on Pentax
05-07-2018, 07:49 AM - 2 Likes   #2
normhead's Avatar
After all the bother about noise at high ISO being so important that I've seen threads where people advocated buying 12MP full frame over a 16 MP APS-c camera for the supposed better high ISO performance, even when the APS-c had a much higher rating on DxO, I refuse to even read this article.
DPR used low light performance to trash Pentax when Pentax was already pretty good at it, now that Pentax has put some money into increasing low light performance, it's not worth upgrading for. You will never see a bunch of more two faced, target changing hypocrites than DPR.
The question is not whether or not everyone should upgrade, the question is who should upgrade. Wedding photographers, come to mind. Every little bit of high ISO performance counts. Anyone doing low light candids on a regular basis or event photography. And I'm completely over the top tired of having to correct the nonsense published over at DPR. It's getting to the point where if I see DPR in a thread, I'm not going to read it, except to ask folks not to repeat what they read over there, over here.
05-07-2018, 09:08 AM - 2 Likes   #3
ogl
Banned
NR in RAW without the possibility to turn off is the worst thing for RAW shooters. I'm disappointed of such decision for K-1II.
05-07-2018, 09:32 AM   #4
normhead's Avatar
QuoteOriginally posted by ogl Quote
You can turn it off, shoot between 100 and 400 ISO. By the time you get to 800 ISO your image is seriously degraded anyway in terms of noise reduction. You haven't established which is worse and for what type of image. What ruins most of your images, noise, or lack of detail? I know what it is for me, it's noise. I rarely need the level of detail I capture with either my K-3 or my K-1. In fact I can show you landscape images where my K-1 and my wife K-5 using the same lens at different focal lengths produce identical landscapes when viewed on a 4k monitor. The extra resolution of the K-1 made no improvement at all to the image.
Folks don't seem to understand that noise is not part of what you were looking at when you framed the image. All noise is artifacts. You may be more comfortable enlarging artifacts but I have taken many images where noise made using sharpening or even adding an appropriate level of contrast was impossible because sharpening, definition and contrast all increase noise artifacts. As well getting to 800 ISO you are going to see decreases in dynamic range becoming factor. I just have no understanding of why people are opposed to deceasing the effect of artificial artifacts cause by the sensor cleanly and efficiently.
I guess astrophotgrpaher would rather see what was there, with a lot of artifacts, tham a cleaned up image that looks more like what was actually there.
Each to heir own I guess, but forgive me if i don't buy in to the hysteria. Don't want the accelerator chip and if you can be happy with the same level of noise control you get on a K-P, fine use a K-1. If you don't like sensor artifacts and choose to give up bit of resolution, which by the way is ridiculous on a K-1, buy a K-ii. You have choices.
05-07-2018, 09:41 AM - 1 Like   #5
monochrome's Avatar
QuoteOriginally posted by i_trax Quote
I am*. Mostly because DPR said not to.
* the Mail-in update service.
05-07-2018, 09:56 AM   #6
After checking the ISO 100 samples, the cards appear slightly out of focus in the K-1 II image (which I doubt it's due to the field curvature of the lens since that's a D FA 50mm f/2.8 macro).
Botched test? It wouldn't be the first time... they did the same for the K-1, too, IIRC (blaming the lens).
05-07-2018, 10:00 AM   #7
Unoriginal Poster
iheiramo's Avatar
Did they miss the focus with mark II on studio test shot? At least to me it looks less sharp on ISO100 than on original K1.
05-07-2018, 10:45 AM   #8
ogl
Banned
Where is the such mode in the setting of K-1II? I can't find it in manual.
05-07-2018, 10:49 AM   #9
K1 II is not a new camera model like it is between a 5D III and a 5DIV. K1 II is a K1 with minor tweaks. I wouldn't say K1 II image quality is a step back from the K1, it has pluses and minuses (slightly better color rendering and less noise, at the expense of a bit less sharpness). Of course for owners of a K1, paying the full price for a K1 II is not worth the difference of performance, however, paying $550 maybe worth it for some people no tight on camera budget, it depends. For a new buyer of k mount camera, however, the K1 II might be of interest. As for the performance versus other brands, we don't necessarily need 10 FPS or 45Mpixels to take good pictures, the glass is more important, that's where Ricoh should hurry. IMO, less glass and slightly late camera body don't go well together. At some point the whole system should have some advantages. You can print large before you see a difference between a K1 II and a D850, and eventually the print from a K1 II will look better as a print. DPR guys evaluate cameras like technocrats, absolute zero experienced judgement about the merits of a camera system beside reading technical specifications.
05-07-2018, 10:55 AM   #10
normhead's Avatar
QuoteOriginally posted by iheiramo Quote
I have seen many images on all sites that try and do comparison testing, where missed focus makes for differences in the images, that probably won't matter in the real world. The most common thing is different focus points. One picture is sharp in one area, the other isn't, but look at a different area the previously unsharp one is now the sharp one and the other isn't. This is also an issue with APS_c and FF comaprisons. Back in the day shooting an FfFand an APS-c at 5.6. the APS-c camera may have had more of the test image in focus and appears sharper, even though the 36MP FF images was sharper at the focus point. So this is not unexpected when taking in such reviews.
05-07-2018, 11:14 AM - 1 Like   #11
ogl
Banned
It's rather strange to use FF camera till ISO400....
05-07-2018, 04:42 PM - 1 Like   #12
Mallee Boy's Avatar
Sadly what all this does is put doubt in peoples minds...and I am one of those. I have cancelled my order of the K1 Mk2, it is a lot of money and I want to spend that on something that is going to help me get better images.
So for now I stay with the K3 Mk2 until this gets sorted out. I had a D800 and let that go because I was not convinced I was getting any better images from that over the K3.
Back on the fence for now.
05-07-2018, 05:34 PM - 1 Like   #13
monochrome's Avatar
QuoteOriginally posted by Mallee Boy Quote
You’re spot on about introducing doubt - which is probably their objective. I just don’t understand what tiny little Pentax is worthy of so much attention - and is such a threat, and to whom.
Truthfully, for a few moments I wondered whether I should send my K-1 in for the heart transplant. Then I remembered the source of my discomfort.
05-07-2018, 06:07 PM   #14
kiwi_jono's Avatar
I guess I can't argue with most of the points DPR raised (except for perhaps high ISO performance - its different rather than worse) but certainly I think their conclusion is unwarranted and somewhat unfair.
The conclusion put quite minor points way out of context IMO. Sure its a minor upgrade but its still a step forward.
Regarding high ISO, at some ISOs I like the K1 II better than the others and I doubt that my post processing NR will do any better job. On the other hand its a valid point that you can't turn off the NR - but not enough reason to completely bag the camera as a step backwards IMO.
Certainly I don't like how the Sony A7R III processes its high ISO images - at some ISOs it looks darn right ugly (especially over the people photos where its quite blotchy at times). Yet they bag the K1 II.
05-07-2018, 06:08 PM - 2 Likes   #15
Otis Memorial Pentaxian
clackers's Avatar
Somebody of your skills will definitely get better images with the K1 Mk2 vs your existing K3, MB!
af, dslr, full frame, full-frame, ii, iii, k-1, k1, lens, lenses, pentax, pentax k-1, review, sony, video
K3-II + V6 II + XT32C + AD200 = HSS frustration :( morenjavi Flashes, Lighting, and Studio 11 07-29-2017 12:13 AM
Godox AD360 II-N works on Pentax with Cactus V6 II Reb Flashes, Lighting, and Studio 31 07-17-2017 07:32 AM
Use of Tokina 28-70 AT-X F2.8 Pro II (OR AT-X 270 Pro II) W.j.christy Pentax SLR Lens Discussion 8 02-15-2017 04:15 PM
New K-3 ii LV failure on a new K-3 ii ? talkskiwon Pentax DSLR Discussion 7 07-25-2016 04:41 PM
Pentax K3 ii vs Canon 5D mark ii mogge Welcomes and Introductions 49 03-27-2016 02:39 AM
All times are GMT -7. The time now is 03:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
