Originally posted by photoptimist It's only proof of smoothing under two conditions:
1) the scene is indistinguishable from noise.
2) the accelerator is a linear filter.
@photoptimist, you seem to be missing the fact that the low ISO shots show no signal correlation but the higher ISO shots (past ISO 640) do. If you trust that all the shots were done consistently then the difference in the 2D FT plots shows that smoothing is applied (only) at higher ISO levels.
It makes me a bit uncomfortable that Rishi Sanyal said that he took the shots that bclaf then analysed, so we are in the hands of someone who has trouble understanding the problem with changing lenses when comparing two cameras, but if we assume that he did not mess up the shots (and how would he have done that in a manner that correlates with the ISO setting?) then the results posted by bclaf leave no room for doubt/interpretation.
Originally posted by photoptimist It's going to take a lot more that an FFT of the noise to characterize what the chip is doing and whether it affects images in any detrimental way.
It only takes an FT to understand when higher spatial frequencies (aka "detail") have been tampered with.
Whether the images are affected in a "detrimental" way is another question, but there is no doubt that processing is occurring and to RAW purists that is a problem in itself.
Having just read about the quiet, behind the scenes changes of DPReview images, I lost pretty much all trust into the material that bclaf was given by Rishi Sanyal. God knows what happened. I'm not saying the results are bogus for sure, but unless the analysis is confirmed by someone else, I would reserve some scepticism.
