Originally posted by neal_grillot I shoot a lot in portrait (rather than landscape).
according to the e-book. The elongated AF points at the far left and right of the viewfinder are vertical linear sensors and detect the sharpest horizontal points only.
In portrait mode, does it stand to reason that these points would detect the sharpest Vertical point? ...
and are these AF points as accurate as the cross-hatch type?
Yes, and maybe.
Basically, a
+ sensor is good at obtaining focus on any linear textured object while a
- sensor can only focus well on vertical or horizontal lined objects, depending on the orientation of the object and sensor. It goes without saying that, for irregular textured objects, this discussion hardly matters. The
- sensor would be as good as the
+ sensor.
This is why, in the old days, when Pentax cameras like the SFX and SFXn only had one AF focus point, and the photographer tried to focus on a linear texture like a corrugated iron roof surface, or a weatherboard wall, then, in some cases, the camera more easily obtained focus if you turned the camera to vertical, obtained focus and then recomposed your image.
So, yes, if you're shooting objects / scenes with strong linear patterns, then, yes, altering the orientation of the camera will allow those
- points to obtain focus more easily. In practice though, we're now spoilt for choice with modern cameras having multiple focus points and the need for such acrobatics has gone away!
Those
- points are no less accurate than the
+ points - it's just that the
+ points are better at finding focus on a wider range of surfaces.
