Originally posted by texandrews See my response to Normhead; I find that NR is the problem child that for me defies using it as a preset. This is the main reason the K1MKII upgrade looks good to me, and somewhat worth it for the shots I need to do at ISO's above 640. Again, YMMV.
Understood. Just bear in mind that if you want to recover the loss of detail people are talking about in the K-1II files, you'll still need to perform chroma noise reduction as I demonstrated above, or apply some other technique.
In fact, I like the output from both the K-1 and K-1II for slightly different reasons. Initially, I was convinced by the K-1II, but my first processing attempts on the K-1 files were giving me better results, so I switched to a slight preference for that model. However, now that I'm getting to grips with processing of K-1II files, I'd be equally happy with either camera. The differences are tiny, though there are very slight advantages and disadvantages to both in terms of IQ, IMHO. But the K-1II also has improved AF (from what I've read) and hand-held pixel shift, which is pretty neat - and I rather like the noise reduction, though I'd prefer if it was possible to switch it off if desired.
This is all pretty academic for me, as I won't be moving to Pentax for my full-frame needs in the foreseeable future - but I'm sure I'll make the jump one day
