Originally posted by beholder3 So whoever uses Adobe products is showing that he is absolutely happy with major manipulation of raw.
You should tell that DPReview.
Rishi Sanyal asked whether it would be better to use dcraw for the camera comparisons. I answered "yes" and so should many more.
The trouble with ACR (Lightroom and Photoshop) is not just all the "under the hood" processing that happens even if you think you are using "neutral" settings, it is also highly problematic that they change their processing depending on the camera and that their processing is "adaptive", i.e. depends on image content. ACR is just a bad, bad choice for doing comparisons.
Originally posted by beholder3 If it is a stupid idea from Ricoh not not have a software switch for NR, then it is even more a stupid idea from Adobe to not have multiple software switches to turn off the multitude of their hidden raw2jpg cooking.
I disagree.
Although it would be desirable if Adobe gave one a way to turn off all their processing, there isn't necessarily an expectation towards a RAW processor that one is able to see a neutral version of the RAW file; the latter would look very unappealing. RAW processors are typically not meant to be used for scientific measurements or to support sound comparisons of cameras. If someone doesn't like what Adobe is doing, they are free to choose another RAW converter. There are excellent alternatives available.
It is an entirely different matter for RAW files. These come with the promise that they contain all information the sensor captured. Some kinds of modification to the data are fine, as long as they are not destructive. If a RAW file is in some way compromised, however -- say due to lossy compression, clipping black levels, smoothing out noise (independently of whether it is system-generated or scene-inherent noise) -- then one has no recourse at all. One cannot simply choose another software to circumvent the issue.
Originally posted by BigMackCam ...and gave the complainers something else to moan about
I generally value your contributions, but I feel with this one, you are not living up to your usual standard.
This statement seems to be expressing that some people are complaining because that's what they enjoy doing, implying that there is no real cause for complaint. I don't know whether Sony's lossless compression algorithm is sub-par, but assuming it isn't then of course the "complainers" have nothing to complain about. However, anyone complaining about lossy compression or mandatory RAW denoising has a point. One may not feel that these concerns cross one's own threshold for complaining, but one should be tolerant about the needs and desires of others and not label them as "complainers".
