06-17-2018, 07:13 AM   #1
murviper's Avatar
Pentax K-1 & off camera flash
I have a Pentax K-1, my flash unit is AF-540FGZ. (also have Pocket Wizard plusIII)
Trying to figure out how to get the flash off the camera have been unable?
Any help would be great , do I have everything I need or do I need to purchase anything else.
06-17-2018, 07:54 AM   #2
QuoteOriginally posted by murviper Quote
Simplest way: a hotshoe extension cable that supports P-TTL.
amazon.com : JJC FC-P3 1.4m TTL Off-Camera Sync Shoe flash Cable Connecting Cord For Pentax K-30 K-5 K-R 645D Camera : Camera & Photo?tag=pentaxforums-20&
Next option wireless triggers, starting from 'dumb' triggers that just fire the flash in manual mode, to those radio triggers from brands like Cactus and a few others that support a wider range of flash features like P-TTL, HSS or remote power control.
06-17-2018, 08:08 AM   #3
pschlute's Avatar
I use the Cactus V6II units for wireless triggering. You would need two units, one on the camera and one on the AF540. This would give you a comprehensive system as rawr says above with P-TTL; HSS; and full manual control available from the transmitter unit mounted on the K1 hotshoe. If you then wanted to add additional flash units you could buy a Cactus RF60X which has a built-in reciever. The AF540 and RF60X work very well together
06-17-2018, 08:52 AM   #4
If you have more than one of the Pocket Wizards, then you would place one on the camera flash mount, and the other on your off camera flash.
I use Cactus V5 units for my off camera flash needs. I would recommend either the latest in the Cactus (V6, V6II, or V6III) or the V5 units themselves if you do plan on investing in new transceivers (radio triggers).
06-17-2018, 09:52 AM   #5
mcgregni's Avatar
All the above, or get another wireless/P-TTL flash to act as Master/Controller if optical control is sufficient for your needs. I posted here mainly to give you the links to my 2 "Pentax Flash Guide" documents (in the sig below here) , which cover everything you are likely to need.
06-17-2018, 06:56 PM   #6
rr1736's Avatar
TTL cord is available from several vendors
06-17-2018, 09:30 PM   #7
Paul the Sunman's Avatar
The Vello P-TTL cord from B&H works well.
camera, dslr, flash, full frame, full-frame, k-1, k1, pentax, pentax k-1
KEH BF sale 11/24-11/26-25% off Featured,10% off Camera & Lenses, 25% off Accessories bladerunner6 Pentax Price Watch 0 11-24-2017 05:26 AM
For Sale - Sold: (AUS) SMC Pentax-M 50mm/1.4 & A35-105mm/3.5 & MV1 body & DB1 Grip (AUS) ddhytz Sold Items 4 04-22-2010 03:28 AM
For Sale - Sold: [US] K7 Body & grip, K20 Body & grip, DA* 16-50 2.8, DA* 50-135 2.8, & more andyschwartz Sold Items 4 03-09-2010 10:23 PM
For Sale - Sold: ist DS camera & Quantaray 28-90mm lens & accessories, Promaster 7000m flash rockmaster1964 Sold Items 10 01-30-2009 05:57 PM
All times are GMT -7. The time now is 12:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
