Originally posted by WPRESTO To replace a pop-up flash (=small, not very powerful), a Metz 26 AF-2. Decent performance, but the real appeal is compact size. It will fit easily into the flat outer pocket of almost any gadget bag. Uses two AAA (triple-A) batteries.
This little Metz is not bad, but it has no manual mode! You can not use it with K or M lenses. It works with A, F, FA, DA, DFA and all lenses which can communicate with the body. If you can not control the aperture with the cam body the flash will not fire!
The Yongnuo is not bad, but if you need HSS you should go for Shanny or Cactus or the one of the big Metz flashes.
