Originally posted by alvaro_garcia Well, in my opinion it makes sense buying a FF high resolution camera only if you match it with a lens that outresolves the sensor. (In fact any camera in general).
I really don't see that as an issue. The whole concept of a lens out resolving a sensor is muddy at best. Exactly how do you define that and give us an example.
For example every Pentax les that I know of gets higher resolution on a K-3 than on a K-5. The test would be if you ran a resolution test on a lens on a K-5 and you got the same lw/ph on your test chart on a K-3. That would be because the K-5 was already capturing all the detail the lens produced, so the K-3 just adds MP without increasing the lw/ph resolution.
The problem being as far as I know that has never happened. Even my worst lenses produce more resolution on a K-3 than on a K-5. They still aren't very good, but the lens does benefit from a higher resolution sensor. SO to date, I don't know of a single lens that doesn't benefit from a higher resolution sensor. The good ones are still better than the not so good ones. Their order in the great scheme of things doesn't change. No lens on a K-3 magically becomes better than a lens that it was worse than on a K-5.You still get better resolution from a good lens than an average or kit lens.
If you were happy with a lens on a 12 MP sensor, you'll probably equally happy with a 16 MP sensor and even happier with a 24 MP sensor, whether you shoot kit, medium of premium quality lenses.
This is lens selling hype prompted by lens salesmen that really hasn't been thought out or even demonstrated to be true. The new Pentax DFA 50 will perform at a higher level on a K-3 than it would on a K-5. But do you need that level of performance?
If you didn't go for high quality glass before, there's no need to do so now. Your older glass will still perform at a much higher level on a K-1 than it does on a K-3 or K-5. The existence of even higher quality glass for a lot more money is another here nor there. There was higher quality glass before, and most people didn't buy it. Noting has changed.
No one has ever been able to demonstrate with images, this concept of a lens being out resolved by a sensor. It's all al lot of theoretical twaddle as far as I can tell. As long as there are no lenses that don't increase in resolution when put on a higher resolution camera it's an irrelevant topic. A red herring, a waste of your time....
SO far, every lens can have it's image resolution increased by putting it on a higher MP sensor. There are as far as I know, no lenses so bad that's not true. So the whole concept is a fallacy. The whole "you have to have better lens" thing is salesman talk. By that logic, you should have already had the better lens. If you didn't need better lenses for you K-5, you don't need them for your K-3 either. And looking at pixel pitch, a K-1 is lower resolution per square centimetre than a K-3. If you needed a sharpe lens, you should buy it for your K-3. Your K-1 with it's larger pixel sites will be much more forgiving of your lenses than a K-3 will be.
The only person this could be even remotely relevant to, would be the person who already has the best, wondering if he should buy new glass, because there is now something better than what he has. Whether or not you want new glass should be a completely different decision than what camera body you buy. The K-1 will make any FF glass you own better. If you want better than better, that's a whole other issue. If an FA macro was good enough for you on a K-5 or K-3, you'll love it on a K-1.
