Thanks for the feedback, guys. I'd like to use the Samyang 8mm lens PRIMARILY on an infrared converted K-7, and secondarily in FF mode on the K-1.
The first version of the 8mm has been creatively used for IR by Richard Gadd on a K-7 (
Richard Gadd Photography: Painting With Darkness: The Victorian Way of Death). Whether the CS II works as well might be open to question. PF Reviews reports the two lenses are virtually similar--1 gram difference--but user reviews of the two versions are very different. The CS II has higher ratings (but fewer reviewers--4 versus 28). DP Review reports that the lenses are the same--save the detachable lens hood on the CS II. They appear to be the same lens.
I'd like to use it on the K-1 and was hoping the vignetting was not as strong as it is (but the vignetting has its own appeal). Although in crop, it would yield a 12mm focal length and could be of use.
B&H has the Samyang/Rokinon 8mm CS II well priced at $219--the lowest price I've seen. With the Version I at $199, the lens hood is $20--not bad, all things considered.
