08-07-2018, 03:38 AM   #16
Andrea K's Avatar
QuoteOriginally posted by alvaro_garcia Quote
Mixed feelings: some reviewers state worse results from the K1-II and some others state the opposite.
Sincerely I tested all the differences between the k-1 and the k-1 Mark II, also the infamous detail loss at high ISO, and in no one aspect the k-1 is better than the Mark II. And the k-1 is a very faboulous camera.
08-07-2018, 06:59 AM   #17
I have sent my K1 in for upgrade. What I have seen from the shots at Imaging-Resource is that there remain questions about what the accelerator chip does and why/in what circumstances with respect to detail retention. Now there are additional questions about a magenta cast at ISO 100 under longer exposures. I have seen nothing (except Bill Claff's test results) that's in any way definitive about what's going on with detail loss. I say that because if one scrutinizes the Imaging -Resource shots carefully across the whole field, It's a "now you see it, now you don't " business to me, and it calls into question to some extent the vagaries of testing itself. For what I use my camera for, the clear advantages I see outweigh the possible deficits. Everyone should make this decision for themselves!
08-07-2018, 07:49 AM   #18
Andrea K's Avatar
QuoteOriginally posted by texandrews Quote
Ah you mean Bill "Rishi dpthoughts" Claff? If I remember correctly the IR images had a different focus between old and new k-1.
08-07-2018, 09:47 AM   #19
QuoteOriginally posted by Andrea K Quote
Well, I don't think Bill Claff and Rishi are buds, and I don't think he's dpthoughts. He looks to be doing unbiased testing, and he's endorsed I think by Jim Kasson, whom I know to be unbiased. As far as the IR images are concerned....they aren't as messed up as the DPR ones were, and potentially still are as DPR moved its whole operation in between the K1 and K1mkII tests, in addition to all the other problems. I don't think the IR tests are that bad. That said, when you start scrutinizing these scenes as closely as we all have been, the question of how exactly the same everything is comes into, uh, focus.
08-07-2018, 04:00 PM   #20
This is a head scratcher for me too. I've read, and I'm sure you've seen them too, posts saying if you change the exif to say it's a K-1 instead of a K-1 II, the issue goes away. That makes me think it's a software issue, but then there are the comments in one of Camerville's reviews mentioning Nikon and Sony having this magenta issue. What ever happened there? Thinking the cameras in question may share the same sensor, so Is this an issue with the software and RAW processing from a certain flavor of Sony sensor? But why would changing the exif change it other than the RAW editors handle the information differently when they know to do so based on the camera profile?
08-07-2018, 11:55 PM - 4 Likes   #21
I'm probably going to get creamed for even thinking in these terms, but with so many vague conclusions I begin to wonder if allot of the objective thinking isn't rationally influenced under the color of subjectivism...
So much for vagaries.
As for my truth? I simply couldn't be happier with my mark ii, and that is a FACT.
Cheers
08-08-2018, 01:12 AM   #22
MJKoski's Avatar
QuoteOriginally posted by clickclick Quote
AFAIK they do not have any magenta issues. I have owned D800E, D810 and A7r1 which all use the 36MP chip and no issues with current Adobe converters or Capture One. Or RawTherapee (which had a bug BTW when handling black level which caused magenta cast with D810). It does not require very long exposure to get the cast with MK2 - I posted two examples with ~2 second ISO 100 exposures in SirTomster's thread.
08-08-2018, 02:27 AM   #23
Andrea K's Avatar
I'm asking myself what is the purpose to take a shot and then push it +5ev. However I can't see magenta cast in 2'' ISO 100 pushed at +3ev (DCU max). I tried also with Camera Raw, same +3ev, no magenta cast at all.....
ISO 100 - 2'' - +3ev in DCU
ISO 100 - 2'' - +3ev in CR
I compared with ISO 200 pictures, same 2''... same result....
08-08-2018, 02:58 AM   #24
I have been told that this is something that pops up on really long exposures and pushing to the extremes and then looking in the shadows. But I too have not seen this is normal shooting.
This is an iso 100 shot with a 15 second exposure, first the regular shot then one pushed five stops (which I would never do in normal post processing).
It isn't that people are telling untruths, it is that they are doing strange things to their images and pushing them to the extreme and then odd things are happening. For most users who shoot iso 100 and push a stop or two, nothing is going to happen. I don't do much astro photography and this seems to be where this is most visible from what folks have posted. So maybe if you do a lot of astro, you are better off going with the MK I original. Otherwise for about everything else, the Mark II is better from my standpoint.
I agree with the rest of your points, although I haven't found dynamic pixel shift very helpful. I shoot RAW and the only way I can use it is to develop it in camera to a TIFF file and then to post process that. Even Pentax's DCU doesn't do anything with the dynamic pixel shift RAW images except use the first image. If you shoot jpegs then it is probably more helpful.
08-08-2018, 03:22 AM   #25
MJKoski's Avatar
How do you explain this: Mark I vs Mark II ISO Comparison Plus Files - Page 3 - PentaxForums.com
Nothing special done except exposure push. All my ISO100 exposures look like that when pushed beyond 4EV. Trying to adjust tint to get rid of the magenta results in very weird looking images. Are there again some uncalibrated sensors or similar issues in some models while others are good?
08-08-2018, 03:42 AM   #26
Andrea K's Avatar
QuoteOriginally posted by MJKoski Quote
Ehm I think that you have to start from a "gray" tone picture.
08-08-2018, 04:37 AM   #27
MJKoski's Avatar
I just wrote that the same cast is present in all ISO100 exposures when pushed. This again suggests that RAW conversion fails or ISO100 is not the real base ISO of MK2 but something higher. Have to do ISO100 vs 200 comparison using multiexposure averaging which allows huge boosting of moderately high ISO value images. It will not remove the cast but shows it very clearly.
08-09-2018, 07:09 AM   #28
I have both the K1 and the K1-II. Based upon my experience, My K1-II performs as advertised. AF is a little better and the shutter shock that my K1 experiences is a non issue on my K1-II.
As far as magenta tint goes, here are two photos from My K1 I took at an air show in July of 2017. Both shot at ISO 400. The only difference is shutter speed in photo #1 is at 1/250 sec. Shutter speed in number 2 is at 1/500. These were post processed in PDCU. Enjoy.
PENTAX K-1  Photo
PENTAX K-1  Photo
08-09-2018, 08:02 AM   #29
Andrea K's Avatar
QuoteOriginally posted by gaweidert Quote
I had forgotten to write it, I too no more shutter shock with Mark II.
08-09-2018, 10:21 AM   #30
rodaballo's Avatar
Please, could you develop this issue? Was your K-1 giving shutter shock with lenses other than the DFA 28-105? Has shutter shock disappeared on K-1 II under the same lens and conditions? This is strange, as apparently the shutter mechanism remains unchanged between K-1 and K-1 II. Would this mean that shutter shock can be avoided by software?
af, bit, camera, dslr, frame, full frame, full-frame, ii, impressions, k-1, k-1 ii impressions, k1, multiexposure, noise, pentax k-1, shock, shutter, shutter shock, tricks, user real world, world impressions
K-1 II AF-C Real World Report MightyMike Pentax K-1 20 06-06-2018 11:10 AM
KS2 User 1 and User 2: Unique Display Color Selection Won't Save in Each User Mode. chimpit! Troubleshooting and Beginner Help 2 06-07-2017 08:10 PM
Hello folks, old GR user and 645 user - new GRV user and 645Z user, coming fr Leica. bilbrown Welcomes and Introductions 3 02-28-2016 03:59 AM
The Pentax Q - a real World user review pinholecam Pentax Q 71 01-12-2013 06:40 AM
All times are GMT -7. The time now is 09:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
