Hi guys:
I got the dreaded mode dial issue on my K1. I am out of warranty and got my K1 from the pre-order batch from B&H around the May 2016 timeframe. I have over 12k actuations, so was luckier than other folks. Since I was out of warranty, Precision Camera said they would charge $358 to fix it.
I thought it was a bit stiff for a known issue that should have been a recall type scenario. And not gotten a favorable response from Pentax (they just referred me to Precision), I deliberated on what to do. On a couple of threads, someone said it might be a cold solder , or a bad ribbon connection... then doing some more googling, ran into a youtube video on how to replace the top cover of the K1. That got me thinking if I could repair this myself since it seemed something a handy person could do.
I am here to share my experience. And provide some info on what is the issue (at least the issue that I had) . I cannot provide repair services or advice since this is a delicate piece of equipment. Please do not open your K1 unless you feel qualified to do so and assume the responsibility to do so.
The broken part:
If you see the photo's, there is a black plastic dial that holds a metal prong (spring contact thingie) that contacts a pcb which governs the Camera mode (M, B, Av Tv etc). This piece sits directly under the Mode dial.
The metal contact piece is held on to the plastic dial by 4 tiny projections. These are less than half a millimeter each. These projections attach to 4 holes on the metal contact. What keeps the metal piece attached is that they melted 2 of the 4 prongs on to the metal piece. That melted portion breaks off over time and the metal pieces comes loose. When that happens, the tension of the spring is lost and it no longer contacts the dial mode pcb which being an open circuit defaults to M mode.
My first thought is, even if they wanted to attach a high tension part to the plastic piece, they should have melted all 4 prongs instead of just 2. But overall, a better design should have been thought of. The part looks very cheap and like a toy from Hong Kong from the 60's... (for those old enough to know the reference).
The Fix:
I am not sure I did a good job, but I just superglued the metal part to the plastic dial... hope it stays on, now that there is more adhesive area than 2 melted prongs, on the other hand, superglue is brittle. I cannot be sure this will hold on for long...
However it held through testing.
I closed up the part, reattached all screws and tested and it works fine.
I can choose all Modes correctly. looks like my K1 is working fine for now.
Hope this helps you guys.
Much thanks
Arif
PS: In the photo's I marked 2 prongs with an "X" these were the ones that were melted and broke off. The other 2 with check marks could be reused and melted to re-attach the metal prong again.
