Originally posted by pentaxian13 Kelvin 5500, when your field monitor is on does the subject show on your K-1 as well. In other words, displays shows the same image on the field monitor and the K-1? In order to see the image I have to use live view.
With an external monitor connected to the camera via HDMI cable, turn on Live View to send the electronic view to the external monitor. The camera built-in monitor screen is simultaneously disabled which significantly extends the camera battery life. Everything that you would usually see on the camera monitor screen is then displayed
only on the external monitor; including menu screens, White Balance settings and Custom Image settings. Whenever you want to revert back to using the camera built-in monitor screen, just turn off the power button on the external monitor and the camera will automatically switch back to the built-in monitor. You do not need to disconnect the HDMI cable to do this.
I hope this information helps you.
Dennis
