I know that everyone has their own unique approach to thinking about how to shoot and I respect that! That's what makes us all individuals.
My particular way of doing things is to break things down in to steps and consider each step in the order they occur. It's not 'right' or 'wrong' per se. It does bring a great deal of clarity to my thinking about what I am doing and helps me make more effective decisions about adjustments.
Originally posted by Des One thing that hasn't been mentioned is whether HD lens coatings have reduced the need for a C-PL.
There are two scenarios here:
1. C-PL is in front of lens
If we expand upon UncleVanya's previous post:
Originally posted by UncleVanya Sensor | Color Filter Array (CFA) | Light < --------
We get:
Sensor | Color Filter Array (CFA) | Lens | C-PL | Light < --------
in this case It's all about what I want to do with the light
before it enters my lens - and therefore my use of a C-Pl has no relationship with which lens I am using.
I'm already done with thinking about what I want to do with the polarization aspects of the light before I ever start thinking about what I want to do with the lens. The reason for this is because this is the order in which these things occur. I keep them separate.
2. C-PL is behind one or more surfaces with HD coatings (drop-in filter)
Sensor | Color Filter Array (CFA) | C-PL | Lens | Light < --------
In this case the subcomponent of the light that is scattered internally as it passes through the lens may not have the same polarization state. Therefore the C-PL may have reduced modifying capability.
Even though my working style is essentially the same in both scenarios, my mental model is quite different. I think about what the C-PL is doing
when it does it.
Now, with all of the above being said, there is a reverse case to consider:
Q: Is there a case when the
lack of HD coatings contradict the use of a C-PL?
A: Yes. In extreme contrast situations (high illuminance) especially if both the lens and the C-PL do not have excellent coatings, you can get a lot of internal reflection between the front element and the filter so you're better off not using the filter.
