4 Days Ago   #1
K-1 AWB and SR setting on tripod
Hello,
I'm going over the settings in my K1 for a shoot, tomorrow. I consulted the manual, but didn't find it. So 1. How do I set my camera to Auto White Balance? 2. When using a tripod, do I leave SR on? Thank you very much.
Terry
4 Days Ago   #2
QuoteOriginally posted by TerryL Quote
Auto White Balance
Press the left button on the 4-way pad, then select AWB. If you have C20 set, press the AF point selection button first.
Always turn SR off when on a tripod.
4 Days Ago   #3
Paul the Sunman's Avatar
Hello,
If you're using the self-timer or the remote control trigger, SR will automatically be turned off (unless you set otherwise in C21).
4 Days Ago   #4
Adam,
When I press the left button on the 4 way pad, it just moves the auto focus spot indicator over to the left. I'm not getting that screen.
Terry
---------- Post added 10-11-18 at 02:58 PM ----------
QuoteOriginally posted by Paul the Sunman Quote
I do use the 2 second delay, does that turn it off. That would be great.
Terry
4 Days Ago   #5
Then just press the AF point selection button first (see post #2).
Yes, it turns it off. This is my go-to.
4 Days Ago   #6
I have back button focus set up. I guess I'll get this figured out. At list I know what to look for. Thank you.
Terry
---------- Post added 10-11-18 at 04:39 PM ----------
Got it. Put it in LV, pressed the left button on the 4 way pad, and there it was. Sweet. Thank you.
Terry
3 Days Ago   #7
eccs19's Avatar
Terry
Terry
You don't actually have to go into LV to do it. This works, but not needed. The button to press to switch out how the 4 way works is just above the 4 way. I believe it's the right most one. Don't have camera with me, so can't 100% be sure.
2 Days Ago   #8
QuoteOriginally posted by eccs19 Quote
Thank you, Mark.
Terry
awb, button, dslr, full frame, full-frame, k-1, k1, pad, pentax k-1, press, selection, sr, terry, tripod
Does Pentax SR result in more image noise than DSLRs without in-body SR? Lew Dite Pentax DSLR Discussion 49 05-21-2018 06:58 PM
AWB at extreme low light and high ISO lotech Pentax K-1 26 12-13-2016 03:13 AM
HELP!!!!! - K-7 AWB setting in TV mode problem Win Heron Troubleshooting and Beginner Help 6 11-07-2016 08:20 AM
K-30 "AWB in Tungsten Light" setting does not work TropicalMonkey Pentax K-30 & K-50 6 11-30-2012 01:36 AM
K-x AWB better than K-5 AWB WerTicus Pentax DSLR Discussion 14 12-20-2010 02:31 PM
All times are GMT -7. The time now is 09:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
