10-17-2018, 12:18 PM   #16
Did you try "Pixel Mapping" in settings, menu 4 of your camera ? I got some trouble with "hot pixel", but I could solve the problem with this function.
10-17-2018, 12:31 PM   #17
QuoteOriginally posted by siegbert Quote
I didn't. It doesn't look like the usual stuck pixels. I'll give it a test on the off-chance.
Rawtherapee's hot-pixel function in the demosaic section seems to do a good job of removing stuck pixels too
10-17-2018, 02:50 PM   #18
Newbie here. I've been messing with this issue a bit as well and haven't really made much progress. If it's any help here's my findings after doing the firmware update to v1.5 (v1.40 addressed this issue - well apparently it did). Granted I did this on the K-1 mark 1 instead of K-1 II, but the difference I did see seems negligible, and if anything worse. Settings were 2min exposure at ISO3200 with the lens cap on: I did this purely to test the before and after difference. I've had worse issues with this than seen below when doing actual star photography. Maybe the cold has an effect? Anywho, 1:1 crops:
Firmware v1.0
Firmware v1.5
Firmware v1.5 after pixel mapping
10-18-2018, 11:01 AM   #19
Very interesting. I did the same test "before and after" the Pixel Mapping with K1 mark 1, V1.5. But I got rid of the problem. I used 30s and ISO100 for my comparision with lens cap on in a dark room.
dot, dot issue, dots, dslr, full frame, full-frame, image, issue, k-1, k-1ii, k-1ii white dot, k1, long exposure, opportunity, owners, pentax k-1, white dot
K-1 white dot issue. ? Gimbal Pentax K-1 & K-1 II 516 10-19-2018 09:27 PM
Ricoh Response to 1.4 upgrade, white dot problem, etc. rcolman Pentax K-1 & K-1 II 10 06-18-2018 11:17 AM
Positive/Successful experiences with fixing the white dot issue on K-1? awscreo Pentax DSLR Discussion 6 09-01-2017 12:19 PM
Lost white dot bassek Pentax SLR Lens Discussion 15 09-06-2012 10:22 AM
www(dot)filterhouse(dot)com Ed in GA Pentax Camera and Field Accessories 1 05-17-2008 02:04 PM
All times are GMT -7. The time now is 05:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
