Originally posted by funktionsfrei It is possible to damage the shutter with too much sunlight
It is possible. Historically Rangefinder photographers who were careless enough to point their camera to the skies would get a lovely scorch mark or complete burn through of the cloth-rubber shutter. This is yet another reason why lens hoods were considered an essential accessory on early RF cameras.
Metal bladed / composite material shutter curtains like the ones used in the Pentax K-1 are much more durable than the shutters of older cameras, but they still warrant careful maintenance.
Originally posted by BarryE The handbook warns that when mirror lockup is stablized take picture promptly in bright light (defined as artificial light, sun, snow) as it may damage the sensor. So Canon do this function differently ?
No, they don't. Canon just mentions this to protect themselves from liability, It's called boilerplate. And in any case the sensor itself is protected by the sensor filter stack which includes a UV/IR blocking filter which varies in strength from manufacturer to manufacturer - It is designed to attenuate the blatantly destructive frequencies of light from the sun. The chances of completely bleaching the Bayer CFA* from sunlight exposure is
remote. but I have to say that would be a safer way of converting your camera to monochrome**.
* Colour Filter Array
** Currently the only way to do this is to mechanically abrade the CFA off the sensor die - needless to say this will utterly void the warranty and potentially damage the sensor. So perhaps strapping your camera to a synchotron - the only problem I see with this is bombarding a sensor with so many photons will undoubtedly generate a considerable charge that will have to be shunted away before it can reach levels that could damage the onboard electronics.
