Originally posted by Rondec If you pixel shift, you get four shots in a row with ES enabled. But I wouldn't think having the shutter click after the shot would be a big deal either way. I imagine that the K-1 sequel will have a true silent mode where the shutter doesn't operate at all, but this was Pentax's early foray into the realm of electronic shutters.
KP's ES mode is virtually silent, night and day difference to the K-1's ES sound.
Originally posted by Pikselisiirto OVF is so much nicer for composition in most cases, so I just try to hold the camera still while looking, press LV and then shutter button. Pentax could automate this process, but they don't. Also full electronic shutter from the OVF is possible. Just shoot pixel shift and ditch 3 other frames. Pentax could automate this process, but they don't. Bracketing is slower with electronic shutter, but pixel shift is fast. There is probably differences between pixel shift ES and normal ES, but Pentax could give us a choice, but they don't.
I noticed that K-1 card writer slots are not fast and the speed is shared. This will increase capture delay with timelapses with full quality and even more, if using two cards. Pentax could offer ES option for timelapse to maintain shutter durability, but they don't. Only possible option right now is to write a mobile app with Pentax SDK and make a script, but I haven't seen any. There also should be option to turn of the screen in LV because it is draining battery quite fast.
K-1 could do more, but firmware has limitations. SDK release might indicate that they won't add more features through the firmware.
That's a curious process that I would like to know more about. I mean, I just tried it now, but my LV mode has Face Detection set up (which actually works fantastically, eyes typically prioritised. I'm now wondering if I can use this tactic a little for certain shots, either have my LV mode set for the same spot point (centre or somewhere else), then frame the shot in OVF but don't rely on PDAF for the focus, then quickly press LV and then Focus and take the shot, because 9/10 the LV does a better focusing job
Is this what you sometimes do?
