11-14-2018, 02:01 PM   #1
Fenwoodian's Avatar
$7.81 Vertical Grip For Pentax K-1 Cameras
I don't shoot many vertical (portrait) oriented photos, most of mine are horizontal format. So, I'm not one to have a heavy/bulky battery grip attached to my K-1 camera full time.
However, for those rare occasions when I do shoot vertical format, I've found a $7.81, Chinese, hot shoe "thumb rest" that provides the extra needed support. On my K-1 it does not block any of the controls/button/displays.
I'd tried other thumb rests on my K-1, but they didn't work because they had straight shafts. This one has a bent shaft which is needed to compensate for the hump on the top of the K-1 camera.
When I first started using it, I found that the bare metal surface on the end of the rest was uncomfortable on my thumb. So, I attached a nose pad that I use on my glasses. That made it much better. You can buy these nose pads at your local optomitrist or department store or drug store.
I find that I like this padded hot shoe thumb rest so much, that I'm keeping my right thumb on it even when taking horizontal photos.
Mine took 3 weeks to arrive. So if you order one be patient. I'm sure that there are many others on Ebay who also sell this type of hot shoe thumb grip if you choose not to order this particular one.
PENTAX Q7  Photo
PENTAX Q7  Photo
11-14-2018, 02:25 PM - 2 Likes   #2
Docrwm's Avatar
Honestly, it looks good but I'm unsure of putting all that weight/torque on the hot shoe.
11-14-2018, 02:31 PM   #3
Fenwoodian's Avatar
QuoteOriginally posted by Docrwm Quote
Good point.
I did a bit of Googling on this subject and here's some comments I found:
As for damage from physical cantilevering, the thumb rest puts a lot less force on the hot shoe mount than a heavy flash would.
I have one of the so called "cheapies" made by Fotodiox. Is is well finished and well made. It had a little play which I took out by taping a piece of Dymo label tape to the bottom of the shoe insert. Fits well and slides out easy. No damage to the hot shoe whatsoever.
Google and you'll find a few examples of detached hot shoes on Fuji's due to a thumb rest.
I just had my X Pro 1 into Fuji Repair for a loose hot shoe. I'm sure it was from the thumb rest. They replace the entire top plate for this repair, so it's not cheap.
Used a hot shoe thumb rest for more than 2 years. no problem at all and love it.
As soon as I was aware of the existence of a hot shoe based thumb grip, I dismissed the idea of using one. The anchor points on a shoe are tiny relative to leverage put on by a thumb extension. That isn't to say a thumb grip will break the camera, but it may, and in beefier hands it probably would. A camera dropped onto the grip almost certainly will loosen or detach the hot shoe. Small amounts of leverage over a long period wear the threads of whatever it is anchoring the contact to the body.
My camera has survived for years with a thumb rest attached. I don't have any concerns about using one. The significant improvement in ergonomics is worth the risk. Mind you, I only use primes...swinging it around with the bigger zooms on might do some damage..
I find myself agreeing with the last poster. In the future, I'll use my thumb rest with only my lighter lenses, not with my heavier lenses.
11-15-2018, 02:40 AM - 1 Like   #4
pid
does not make sense when the hot shoe is blocked
11-15-2018, 03:28 AM   #5
k1man's Avatar
dont get pissed but it is a piece of cheap charlie rubbish that you fell for, waste of money, ian
camera, dslr, format, full frame, full-frame, k-1, k1, nose, pentax k-1, photos, shoe, store, thumb
Vertical grip Ray Cox Pentax Medium Format 18 04-20-2018 01:09 PM
Pentax 67 Focusing Screen 61/60 vs 81/80? Alex833 Pentax Film SLR Discussion 4 01-06-2017 04:04 PM
Cameras cameras cameras Lurch Pentax DSLR Discussion 16 04-14-2013 02:54 AM
How to see images vertical images after download as vertical ? netuser Troubleshooting and Beginner Help 8 08-28-2009 03:48 PM
battery grip/vertical grip rjburgos Pentax Camera and Field Accessories 4 12-04-2007 08:35 AM
All times are GMT -7. The time now is 09:15 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
