Show Printable Version 6 Likes Search this Thread
11-29-2018, 08:49 PM - 3 Likes   #1
Very Unscientific comparison between Sandisk Extreme Pro SD and Sandisk Ultra MicroSD
So with the Sandisk Ultra MicroSD cards on sale for $19.99 on Amazon this last weekend, I could not resist and purchased 2 for my cameras.
My hope was that their write speeds were fast enough on the K-1 and the K-1 Mark II to match my single 128gb Extreme Pro. Since that chip is overkill with the K-1 write speeds only up to 30MB/s. Why buy cards rated at 3 times the speed the camera can write.
Well the cards arrived and I did a very (very) unscientific test.
I setup both cameras with the same setting and to Manual Focus. 1/5 second ISO 100 low aperture. Also set to Continuous shooting: High
A K-1 and a K-1 Mark II
I then pressed the shutter button down and held it for 15 to 20 seconds to take a bunch of images and then release them at the same time.
I wanted to see how fast the cameras would write to each card.
I did say unscientific!
Well after multiple tests, the Ultra took slightly longer to save all the images. Around 3 seconds each time.
I then swapped the memory cards and tested them in the other camera in case there was something special w/ the Mark II.
There was not, the camera with the Ultra MicroSD's were slightly slower.
To be honest, not slow enough for me to not use the cards though.
Personally, 95% of my photography will not need to worry about the write speeds since I do Landscape and Astro.
So the Ultra is slower and for some that might be important. But it is not slow enough for me to worry about.
And a video to show my so very unscientific test.
11-29-2018, 09:46 PM   #2
Not a Number's Avatar
FYI the FAQs that have been removed on the Ricoh/Pentax support pages warned against using MicroSD cards. No reason given.
11-29-2018, 09:58 PM   #3
Otis Memorial Pentaxian
That is my memory as well.
Conventional wisdom has been that even with an appropriate adapter, MicroSD cards are not intended for regular use in devices supporting regular SD cards. I suspect capacitance concerns due to the extra set of contacts inside the adapter.
11-30-2018, 02:08 AM   #4
Dartmoor Dave's Avatar
I'm thankful that we photography types are rational people who understand that the only difference a memory card can make is in write speed and reliability. When I've got my classical vinyl dealing hat on I talk quite often with some serious hi-fi nuts, and those guys would be arguing that your choice of card can make an actual difference in the photos. They'd be saying that you really need to connect your camera to your computer with a $500 usb cable for better colours and contrast. Heck, they'd be saying that even the mains cable that you use on your battery charger can make a visible difference in your photos.
So I'd just like to say thank you, everyone, for being photographers instead of audiophiles.
(Full disclosure: yes, I'm a bit of a hi-fi addict myself. But I've never drunk the Kool Aid that makes you think that digital storage methods can sound different.)
11-30-2018, 04:05 AM - 1 Like   #5
Digitiser of Film
BigMackCam's Avatar
QuoteOriginally posted by Dartmoor Dave Quote
So you don't fancy one of these, Dave?
Crystal Cable's Crystal USB Absolute Dream
11-30-2018, 05:22 AM - 2 Likes   #6
I replaced all the dials on my K-3ii with genetically engineered teak wood that's been dried in ancient Egyptian kilns and laquered with the extracts from rare Uzbek honeybees, all engineered to absorb stray light that might enter the viewfinder and make my photos less sharp. The set was only $4500.
Are you saying that was a bad investment?
11-30-2018, 06:44 AM   #7
I do know that only certain mini sd cards are suitable for dash cams. Something about them not holding up to a lot of writes and deletions.
11-30-2018, 06:53 AM   #8
eccs19's Avatar
Only time I've had to worry about write speed is if I'm shooting RAW to both card slots. If I'm only shooting RAW to one, I have no issues with speed for my style of shooting, but writing to both cards, I do notice it occasionally.
11-30-2018, 11:45 AM   #9
I kept looking for information to indicate it was not recommended and never found any. So I figure I would buy these.
They will be in slot 2 on my cameras and normal SD cards in slot 1. So I will be curious if I even do run into issues with these.
camera, dslr, full frame, full-frame, ii, k-1, k1, mark, pentax k-1, sandisk, speeds, test, write
SD card Just bought an Sandisk Ultra SD XC1 64 Gig Card and comes up with error Craig Hickman Troubleshooting and Beginner Help 10 07-30-2018 11:37 PM
Sandisk Extreme Pro 2-pack SD card deals are back! Adam Pentax Price Watch 8 06-29-2016 10:12 AM
Memory card SD vs microSD HanSolo Pentax DSLR Discussion 10 12-28-2015 11:46 AM
Sandisk ultra or Sandisk extreme totcambiu Pentax Q 5 01-31-2013 12:22 PM
Very, Very unscientific, but of interest Ed in GA Pentax DSLR Discussion 41 06-21-2008 12:00 PM
All times are GMT -7. The time now is 09:06 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
