12-24-2018, 11:16 AM   #16
mattt's Avatar
Anyone use the Voigtlander Colour Skopar 21mm on K-1? There are a few k mount kicking around...
12-24-2018, 11:22 AM - 1 Like   #17
clackers's Avatar
QuoteOriginally posted by mattt Quote
I've got one. I've used APS-C lenses in preference to it because it's not sharp.
It is a pancake, though, so if you weren't at all serious about your ultra-wide photography, it takes up little room in your bag, like the DA15.
12-24-2018, 12:42 PM - 1 Like   #18
jlstrawman's Avatar
M20/4 is hardly disappointing.
My thoughts, also. I was patient and found my excellent copy for around 200 USD.
I use mine on both FF and APS-C.
12-24-2018, 12:51 PM - 1 Like   #19
QuoteOriginally posted by DSLRnovice Quote
How would you compare the FA20 with the FA20-35?
I can check for you. I am fortunate to have both as I have been collecting for many years.
In refernece to your question re: edge sharpness, I have to say that the FA20 is most definitely the best of the bunch discussed thus far - without doubt.
12-24-2018, 03:23 PM   #20
david94903's Avatar
I was wondering if the DA16-45 might come out similar or better than the M20. While the color and contrast is really terrific, the edge and corners can go soft in FF probably due to field curvature. The real disadvantage in FF is the size for using only the 20-24mm FL. (My DFA 28-105 performs well at 28MM) There is something very appealing to the size of the M20 that would make it worth the trade offs.
I'm thinking you're right about the corner issue. I'm betting the DA16-45 are similar (DA being sharper) at the center but the DA goes softer at the corners than the M20/4. I have a D-FA24-70 and the M20/4, though not quite as sharp, holds it's own for a forty year old lens (see attached comparison)
And yes, the size of the M20/4 is fantastic. Easy to carry in a pocket. Though compared to the D-FA15-30, the A20 and FA20 are also a comfortable size too.
PENTAX K-1  Photo
12-25-2018, 10:02 AM   #21
QuoteOriginally posted by david94903 Quote
The cropped images do look close. Are they center frame?
12-25-2018, 10:27 AM - 4 Likes   #22
But I am not sure if the M20 will offer better IQ than the DA16-45.
I've owned both lenses, but I've only shot the DA 16-45 on APS-C. On APS-C, I much preferred the M 20/4. Not that there's much difference in measurable qualities between the lenses. They both exhibit comparable sharpness (at least on APS-C). But I found that, while I was initially impressed with the DA 16-45 (it's sharp all the way to the corners on APS-C), the images I got from the lens didn't wear well over time. Something indefinable and immeasurable but very real in the color contrast and rendering was missing. Whereas I had the opposite reaction with the M 20/4. It doesn't bowl you over at first either with sharpness, contrast, or saturation, but there is something subtle and life-like in the rendering and colors that you begin to appreciate more and more over time. Whoever designed the M 20/4 had a finely developed aesthetic taste; whereas the DA 16-45 was the first lens Masakazu Saori designed to production, and (I suspect) suffered from his lack of experience (he was barely out of college at the time). Saori would later go on to become one of the pre-eminent lens designers in the world, but he was hardly that in 2003 when he was working on the DA 16-45.
A couple of images from the M 20/4, shot with the K-1:
12-26-2018, 12:24 AM - 1 Like   #23
david94903's Avatar
Yes, they are close to center frame.
12-26-2018, 03:01 AM - 1 Like   #24
Ash
Community Manager
Ash's Avatar
Greg, those images exude 3D rendering and colour contrast. Thanks for sharing those. It will provide a good comparison for me when I test out the FA 20.
12-26-2018, 01:25 PM   #25
QuoteOriginally posted by northcoastgreg Quote
Those images from the M20/4 look very nice. I do not normally take the 16-45/4 with me since getting the K-1. It takes up so much space. But I have been thinking that I need to use it at 20-24mm just to see how that FL works for me. Then I can decide whether or not to look for the FA20. The M20 would be great if I could be found at a more reasonable price.
The DA16-45 in FF does vignette at 20mm at most apertures, but the color and flair resistance has always been good.
12-31-2018, 09:41 PM - 1 Like   #26
Comparisons of multiple 20mm lenses all at full frame on the k-1
My method is basic and systematic to avoid bias.
I have taken photos of a single scene from a tripod platform. Photos taken wide open and at f8 (with one exception - three shots were taken with the FA 20mm these being f2.8, f4 and f8). All in camera settings were kept the same. Shooting was in manual mode at infinity focus. Metering was across the whole frame.
Lens tested are:
Tokina 20-35mm f3.5-4.5 version II
Pentax M 20mm f4
Pentax K 20mm f4
Pentax FA 20-35mm f4
Pentax FA 20mm f2.8
SMC Takumar 20mm f4.5
Here goes - lots of shots with centre and corner crops too
12-31-2018, 09:51 PM - 1 Like   #27
Full scene followed by crops of the centre and corner at f3.5 and f8
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
12-31-2018, 10:01 PM - 1 Like   #28
Pentax M 20mm f4
Full scene followed by crops of the centre and corner at f4 and f8
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
12-31-2018, 10:14 PM - 1 Like   #29
Pentax K 20mm f4
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
12-31-2018, 10:24 PM - 2 Likes   #30
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
PENTAX K-1  Photo
20mm, a20, distortion, dslr, flickr, full frame, full-frame, images, k-1, k1, lens, lenses, pentax k-1, post, recommendations, recommendations for 20mm, sense
So many 50mm and so little money (and experience) gump Pentax SLR Lens Discussion 10 09-23-2018 10:04 PM
Do you own a *sharp* (& cheap, so manual ok!) wide lens? Need recommendations! mishmatta Pentax SLR Lens Discussion 34 10-23-2011 07:30 PM
Nature So so tall, small, so beautiful newmikey Post Your Photos! 3 06-03-2011 03:11 AM
Wanted - Acquired: Pentax FA 20mm or Pentax A 20mm loveisageless Sold Items 2 01-13-2011 12:00 PM
New to DSLR so I bought a K-X, any recommendations? buffalobrian Welcomes and Introductions 20 03-12-2010 06:57 PM
All times are GMT -7. The time now is 05:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
