Originally posted by hadi
rubber grip on K1 coming undone
Same here. I asked for some ideas here a while ago. I purchased some glue (done some research, found glue that would suit, asked the seller who told me another choice that was wrong..). The grip was getting lose on the mid-high of the grip, so I sealed it, some of the glue stuck at the edge of the grip that would leave some white traces (not good whenever reselling the camera, obviously would have an impact in price). I was happy but decided that I would use another adhesive next time. Then, few month later, the lower part of the grip started for get lose, so I bought some double sided transparent tape and stuck it under the grip, it was fine. Except, I understood why the grip came lose, is because the grip material gets permanently stretched over time, so that after I glued the rubber layer tight to the grip, there was excess rubber material at the edges of the grip that would prevent proper sealing, so I have to cut 0.5mm of excess grip rubber, and now obviously it is visible as it doesn't fit perfectly at the edge. Anyway, when I pulled off the rubber to insert glue adhesive, I saw that the original adhesive band used by Ricoh looked like old stuff, I just wondered if there was any point to save money on that kind of adhesive. Also, I looked to buy spare rubber grip part for the K1 and couldn't find, so I gave up. We'll see when the grip rubber will stretch further, I'll probably have another camera model by then.
The experience taught me that it's better to remove the whole rubber piece remove the original adhesive so that to get a clean surface. And use a glue that is slow to stick so that it is possible to position the rubber layer precisely on the grip. And the glue must not dissolve the rubber otherwise the rubber itself gets lose again after some time.
