02-02-2019, 03:29 AM   #1
wombatwal's Avatar
K-1 II underexposing
I have had my K1-11 since early January. Have taken it out for 3 photoshoots and each time it has required at least a 3 stop over exposure for proper exposure. The exif data on all of the images in camera and on the downloaded images say +- -3. Exposure bias -3 EV. Do I need the camera looked at or is there a setting that is wrong in the camera? I cannot find anything in the menu. Thanks.
02-02-2019, 03:47 AM   #2
Ash
Ash's Avatar
Is this with or without flash? I’ve experienced the same with bounce flash so far. Unless I press the green button in Av mode, the flash doesn’t expose the scene at all. This is in P-TTL mode. But without flash, the camera has been accurate with metering and exposure.
02-02-2019, 03:50 AM   #3
wombatwal's Avatar
No Ash, not flash.(No Flash Ash ) Have not used flash at all. All day time exposures, no night shots, some sunrise ones though.
02-02-2019, 03:59 AM   #4
QuoteOriginally posted by wombatwal Quote
So you set exposure compensation to plus 3 ev and the exif says minus 3 ev ? Are you using manual exposure mode ?
02-02-2019, 04:05 AM   #5
wombatwal's Avatar
Yes, only manual. I shoot 3 stops over exposed but the exif says -3 EV. When I shoot at the correct exposure according to the exposure guide, the shots are at least 3 stops underexposed.
02-02-2019, 04:21 AM   #6
Ash
Ash's Avatar
M mode, and you go by the camera’s metering, or are you going by sunny 16 rules? If the camera says you’re overexposing and yet the EXIF says -3EV, something is awry with the metering.
02-02-2019, 04:24 AM   #7
pschlute's Avatar
I am confused. What is your exposure compensation set to on the camera ?
Be best if you post some examples
02-02-2019, 04:29 AM - 1 Like   #8
That's normal. In M mode, if you set the exposure compensation to -3ev (press the [+-] button next to ISO button on top of the grip, or use the smart dial to set exp. compensation), the exif will say -3ev and you'll have to overexpose with manual settings to +3ev in order to achieve proper exposure. The reason is that in M mode, the exposure meter indicates the exposure value relative to the exposure compensation being set. If you set exposure compensation to -3ev, the AE meter bar indicates 0ev relative to the -3ev you have set as exposure compensation value.
02-02-2019, 04:31 AM   #9
wombatwal's Avatar
Yes, only by the camera's metering. I overexpose by 3 stops.
02-02-2019, 04:32 AM   #10
pschlute's Avatar
That's normal. In M mode, if you set the exposure compensation to -3ev (press the [+-] button next to ISO button on top of the grip, or use the smart dial to set exp. compensation), the exif will say -3ev and you'll have to overexposure manually by +3ev. The reason is that in M mode, the exposure meter indicates the exposure value relative to the exposure compensation being set.
Yes , what he said. With EC at -3, in Manual mode the meter at a centre reading will give a 3 stop underexposure. You then counter this by overexposing by 3 stops. Solution is to reset the EC to 0
02-02-2019, 04:33 AM   #11
wombatwal's Avatar
I only shoot in manual, there is no exposure compensation set. Unless there is some setting that I am unaware of.
02-02-2019, 04:37 AM   #12
If the exif says -3ev it is exposure compensation set by camera software. So unless your camera firmware is wrong version, it wouldn't be possible that exif indicates -3ev and actual camera exposure compensation is set to 0ev. I would check the firmware version of the K1 II and check the exposure compensation setting.
02-02-2019, 04:38 AM   #13
wombatwal's Avatar
No, I don't press the exposure compensation button in manual at all. Ah, I have just checked this new dial and I had the exposure compensation set on. I have put it onto 0. So hopefully should be ok, will check tomorrow during daylight hours. Damn new fangled cameras
02-02-2019, 04:40 AM   #14
yes, when we get new cameras, it's good to try different settings and observe what the camera does, just to get familiar with how the camera behaves.
02-02-2019, 04:41 AM   #15
Ash
Ash's Avatar
I think you’re onto something there. Relative, not absolute EV compensation determines the EXIF compared to the camera meter.
camera, dslr, exposure, full frame, full-frame, images, k-1, k1, k1-11, pentax k-1
645z suddenly underexposing simianminded Pentax Medium Format 7 03-07-2018 05:26 PM
Underexposing Cerebum Troubleshooting and Beginner Help 3 01-13-2018 06:46 AM
K-5 Underexposing Question Halco Pentax K-5 & K-5 II 2 06-16-2013 12:51 AM
Noise when underexposing, maybe bxf Pentax K-5 & K-5 II 8 08-25-2011 11:40 PM
K10D underexposing? madisonphotogrl Pentax DSLR Discussion 48 06-16-2008 09:03 AM
All times are GMT -7. The time now is 12:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
