02-02-2019, 09:55 AM   #16
Oldbayrunner's Avatar
Don't forget when using a flash your dealing with two separate exposures. 1st being your ambient light the 2nd being your flash exposure. What affects your flash lighting is power and distance. If the power is full then the distance will affect how much light the subject receives. Bounce flash, distance and color one is bouncing off of can affect it. So if your exposures are too dark then you compensate by moving your flash lighting closer. adjusting your ambient light settings or adjusting how your using your flash lighting.
02-02-2019, 04:29 PM - 1 Like   #17
mcgregni's Avatar
It's still hard to be sure, from what the OP has written so far, whether this is a case of equipment failure or user error / lack of experience ....
To help rule out the latter, why not grab a copy of my Flash Guide "Supplement" PDF? This contains a section dedicated to automated flash control considerations with P-TTL.
02-02-2019, 07:18 PM   #18
Ash
Ash's Avatar
Aperture ring set to "A"
It is. That’s what I meant. Sorry it wasn’t stated that way but I always control aperture through the camera.
02-02-2019, 07:19 PM   #19
Ash
Ash's Avatar
QuoteOriginally posted by RedBoomer Quote
Try setting ur camera in manual and flash in pttl. Say 1/200, f4, iso 200. The camera then let's the flash make the exposure. I find when the camera is in Av and flash pttl then there are two mechanisms trying to make the correct exposure and often it isn't right. I have k1ii and 540 flash as well. Good luck with it
Yeah. Or X-Sync? It’s just the first time I’ve had a problem shooting with flash in Av mode. Always seemed to be reliable in the past, with the appropriate FEC set as I alluded to above.
02-02-2019, 07:20 PM   #20
Ash
Ash's Avatar
I've seen software fixes get "broken" again in subsequent releases. The fix isn't sufficiently documented and gets taken out in an update. Or you different teams working on releases and the base release one team is working off of doesn't get a fix the other team adds. It happens all the time in software development.
Okay. Though that should mean others are experiencing it too. It should be a pretty frequent occurrence in real use, so it would be a problem to many. Is this the case?
02-02-2019, 07:21 PM   #21
Ash
Ash's Avatar
QuoteOriginally posted by derekkite Quote
Are you in X mode? Iirc the k3 would set the iso to 800 if i wasn't in X mode.
Not sure why that would be. ISO should be independent of other settings.
02-02-2019, 07:22 PM   #22
Ash
Ash's Avatar
QuoteOriginally posted by Oldbayrunner Quote
Yep. I’m aware of that. I like using fill flash a lot and have done so in the past without any problems in Av mode. The flash is close to the subject and ceiling like I stated before.
02-02-2019, 07:23 PM   #23
Ash
Ash's Avatar
QuoteOriginally posted by mcgregni Quote
Thanks for your suggestion, though I’ve done this kind of work for many years now. No problem with all previous 8 Pentax dSLRs.
02-03-2019, 04:29 AM   #24
mcgregni's Avatar
The problem is though, you're made references to the green button, ISOs and modes that suggest you don't really have a firm grip on things ... That's the impression conveyed. So you allow the question to keep hanging about whether there is an auto-ISO or mode behavior difference on the K1 that you are not aware of, that behaves differently from your previous cameras
Until you say conclusively that you are shooting with specific fixed settings, within the distance / environment limites as detailed in my flash guide supplement, and show a test image to portray the scene as the metering sensors read it, then there will be no conclusion to this. You will be left with the option of taking the camera back and trying to prove a fault for a repair or replacement.
02-03-2019, 04:35 AM   #25
Ash
Ash's Avatar
Underexposed images with bounce flash on K-1 II
I’ll have to change the title of this thread. I’ve just worked out that my FGZ-540 refuses to fire for the exposure. It only flashes for metering but that’s it. Test flash button fires the flash fine. I don’t understand why it doesn’t fire the second time (for the exposure when the shutter is open).
So I go and get my other flashgun. The Sigma EF-500 DG Super. It has worked fine as a P-TTL flash on my previous cameras. On this K-1 it is firing only for the exposure (no metering pre-flash) and always at full power.
Now what? Is it the two flashes or something else? I used the FGZ-540 successfully the week before. Didn’t test the Sigma prior to today though. Can’t tell if the Sigma is compatible or not but I can’t see why not. Any guesses as to the problem here?
02-03-2019, 04:41 AM   #26
Ash
Ash's Avatar
I’ll reiterate, I know what I’m doing here, you can give me the benefit of the doubt on that.
Settings should be visible on the EXIF data of the attached images if desired.
All images pretty much f/5.6 with ISO 200 in low lighting (artificial) and zero EC for both camera and flash in Av mode. Subjects are close (1st image, about 50cm with bounce ceiling flash 1.5m away for both scenarios) and moderately far (2nd image, about 2.5m with front flash for both scenarios).
These are the typical situations where flash should adequately light the subjects without any trouble in P-TTL mode.
02-03-2019, 06:02 AM   #27
pschlute's Avatar
EXIF is stripped on these images.
If the AF540 is firing a pre-flash but not main flash make sure it is not set to Wireless "Controller" mode. The flash on off button should be firmly in the on position, not at the halfway Wireless position. What does the panel say the mode is ?
i don't know if your Sigma is compatible with the K1. it is quite an old model so possibly not. If it should be compatible and is also not working then perhaps the fault lies with the K1 hotshoe/electronics.
Can you find another Pentax flash to test on your K1
02-03-2019, 06:21 AM   #28
Master of the obvious
savoche's Avatar
Maybe not too much help in it, but I just tested my K-1 (original) with a Metz 58 AF-1 (w/updated FW) with the settings you describe above, flash in P-TTL mode, bounced off the roof. All the exposures were spot on. The in-camera lightmeter says 1.5-2 seconds without flash, with flash I get 1/60th.
02-03-2019, 07:23 AM   #29
HippyHippo's Avatar
I apologise if this presents a red herring, but I mentioned inconsistent P-TTL flash metering with the FGZ-540 to a Ricoh Pentax rep at a recent trade show. The specific issue here was occasional random over-exposure (especially with daylight fill).
He indicated that the firmware in the FGZ-540II is better in this regard. But I’ve not got hold of one to try it yet. Are you using the older flash model too?
02-03-2019, 01:27 PM   #30
mcgregni's Avatar
But you must appreciate that you had to understand you were not necessarily conveying that impression ....
The only way to test P-TTL working, by isolating the flash exposure from all other possible influences, is to set M camera mode, set a fixed ISO, a fixed aperture, and a fixed shutter speed, and report exactly what these are. These settings should be such that they completely eliminate all ambient exposure. We still don't have this assurance from your tests so far, as they have been in Av mode with who knows what Flash Sync mode setting, and what ambient exposure level is mixed in there.
I do of course accept that you appear to be dealing with some sort of flash contact or communication issue through the hotshoe, but that's still not absolutely proven by your reporting so far.
The other good thing to try is to use M flash mode on your flashes (again of course with every camera settings fixed to eliminate ambient light), in order to check if your flashes are syncing correctly. You can assess the flash exposure level on a series of shots in M mode as you progressively increase the power, say from 1/32th through to 1/2. At least this would prove whether its a flash contact issue, or if its likely to reside in software, ie the camera is not telling the flash what to output properly in P-TTL mode.
dslr, exposure, flash, flash on k-1, full frame, full-frame, iso, k-1, k1, light, pentax k-1
K30 Clicking Black / Very underexposed images but runs ok with Manual Lens Avishekm1983 Troubleshooting and Beginner Help 13 04-06-2017 11:01 AM
Badly underexposed (near black) images after turning on the camera William George Troubleshooting and Beginner Help 7 02-18-2016 10:18 PM
K500 images coming out extremely underexposed ckaur Troubleshooting and Beginner Help 5 10-21-2015 03:00 PM
K-50 Images Underexposed (Black) aikilink Pentax K-30 & K-50 11 07-08-2015 05:23 AM
Sekonic 358 Giving Me Very Underexposed Images -- Help? reivax Flashes, Lighting, and Studio 10 03-18-2013 08:14 AM
All times are GMT -7. The time now is 09:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
