10-02-2019, 01:25 PM   #31
How do you go about testing the quality of a flash?
10-03-2019, 05:27 AM - 1 Like   #32
UncleVanya's Avatar
QuoteOriginally posted by wings Quote
Loaded question. What is quality in this case? Light output, accuracy and repeatable output, cycle time, ease of use, feature compatibility, the list is large. If you can narrow down to particular criteria I'm sure we can give ideas.
10-03-2019, 09:26 AM   #33
Flash quality
You have made a pretty good list and I suspect that most of you know more about this than myself. The features on a flash will not mean much if the flash does not do what you expected it to do, sorry for the simplification. The criteria I would leave up to you, however accuracy and repeatability is important, maybe very important.
Perhaps another issue would be that if after using a particular flash for a time, that you know that you have to adjust how you photograph something based upon the nuances of the flash. Related to that is that for me I do not want to spend a lot of time setting up a flash. I know that flash technology has come along way since the days when you might have burnt your fingers on flash bulbs, and so imagine that the quality of a flash would have to have some kind of touchstone that takes into account of those advanced capabilities. I have read most of the comments here and will readily admit that your knowledge about this far exceeds mine, so was curious about how you evaluate the quality of a flash.
10-03-2019, 09:45 AM   #34
pschlute's Avatar
Different flashes have different features. If you want HSS and trailing curtain sync or auto zoom then you should select a flash that has those features. They will either work or they wont, there is not a degree of quality here.
If you want a flash that provides the most automation then you need one that can do P-TTL.
10-03-2019, 01:19 PM   #35
UncleVanya's Avatar
Loaded answer. Take pictures using the flash in situations that are "on the edge" to validate boundaries. Power and consistency will easily be evaluated by increasing distance and repeated tests. Some things are subjective like ease of use.
dslr, flash compatibility, flashes, flashguns, full frame, full-frame, k-1, k1, list, p-ttl, pentax k-1
Flash compatibility CapitanXeon Flashes, Lighting, and Studio 24 10-08-2018 04:01 PM
K-50 Flash Compatibility? roberts_camera Flashes, Lighting, and Studio 8 07-27-2018 10:21 PM
wireless flash compatibility lolliiy Troubleshooting and Beginner Help 26 01-31-2011 10:01 PM
Flash bracket compatibility? iht Troubleshooting and Beginner Help 4 08-10-2009 02:56 AM
Flash compatibility Simon Photographic Technique 2 01-09-2007 05:25 PM
All times are GMT -7. The time now is 07:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
