02-10-2019, 12:04 PM   #1
stub's Avatar
using Yongnuo RF trigger as a shutter remote...?
Has anyone used any of the Yongnuo rf triggers to remotely fire the shutter on a Pentax camera ? I'm trying to connect them to my K1 to fire the shutter but without success. Trigger is firing reciever is recieving the signal. Connected the reciever to the X-sync socket on the K1 But the shutter isnt firing.. Also tried setting the remote setting on shutter menu. No success. So is it possible ? What am I doing wrong ?
02-10-2019, 01:11 PM   #2
Sluggo's Avatar
QuoteOriginally posted by stub Quote
... Trigger is firing reciever is recieving the signal. Connected the reciever to the X-sync socket on the K1 But the shutter isnt firing.. Also tried setting the remote setting on shutter menu. No success. So is it possible ? What am I doing wrong ?
Not sure if we have the same units, but for the RF603N II at least, they operate in remote-shutter and remote-flash modes, and the two aren't the same. Could be you've got it set so it thinks it is supposed to firing a flash on the receiver's hotshoe. The sender and receiver should both be switched to TRX position.
02-10-2019, 01:23 PM   #3
Are you trying to fire the shutter via the flash? AFAIK, it works the other way around - you plug the flash into the X-sync socket, and it should fire when you press the shutter.
Check the last paragraph on page 111 of the K-1 user manual.
02-10-2019, 01:27 PM   #4
I use one pair of rf603 and 560-tx with k-70 and this combo works without problem. You only need to use the cable to connect receiver with the camera.
02-10-2019, 02:06 PM   #5
stub's Avatar
QuoteOriginally posted by AstroDave Quote
Im trying to fire the shutter remotely using the Yongnuo RF602 or RF603 trigger.. No flash involved Dave...!!
---------- Post added 10-02-19 at 02:09 PM ----------
QuoteOriginally posted by taktoon Quote
Sounds good taktoon. I have the 560tx unit. Not quite sure what you mean but will have to give that a try out...
---------- Post added 10-02-19 at 02:34 PM ----------
Thanks all. and Sluggo for the pic. Really helped. Sorted the shutter firing problem out.. I was being a bit stupid and using the x-sync socket as I was earlier watching a youtube vid and thats what they used on a Nikon camera.
But now I have a different problem and by connecting the trigger lead to the remote socket. It kills the rear display. So no menu display, live view or pic of image taken. until I take the Jack lead out... Any ideas on this...?
02-10-2019, 02:43 PM   #6
There is a short somewhere. Or miswired. There are three wires, common to one of the other two does the equivalent of half shutter press and full press.
Some wires with plugs have a hefty shoulder that stops the plug from going in far enough to make the proper connection. You could also have a faulty trigger. They don't tolerate any misconnection.
02-10-2019, 02:53 PM   #7
stub's Avatar
QuoteOriginally posted by derekkite Quote
Same thing happens on my K5II.. ?
---------- Post added 10-02-19 at 03:13 PM ----------
Yep...seems your right derekite...!! Its a bit of an iffy joint...
02-10-2019, 05:04 PM   #8
stub's Avatar
If all else fails.. Go to the instruction manual....lol
camera, display, dslr, fire, flash, full frame, full-frame, k-1, k1, pentax k-1, pic, press, rf, rf603, shutter, success, wires, x-sync, yongnuo, yongnuo rf
Can Yongnuo YN585EX be triggered by yongnuo trigger? swanlefitte Flashes, Lighting, and Studio 7 12-06-2017 07:37 PM
RF-600TX replaces RF-602TX in Yongnuo RF-602 Kits adr1an Pentax Camera and Field Accessories 4 02-18-2015 10:14 AM
YONGNUO flash 560III + radio trigger RF-603N mictadlo Flashes, Lighting, and Studio 15 02-18-2014 08:53 PM
Yongnuo RF-603 - Shutter speed help needed ravula Flashes, Lighting, and Studio 7 04-16-2013 04:01 PM
YongNuo MC-20A Digital Timer Remote Shutter Trigger? gybp Pentax Camera and Field Accessories 4 12-26-2010 07:59 PM
All times are GMT -7. The time now is 05:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
