truly, it may be the littlest thing that makes one happy
honey I just want to buy a new camera because of the 1.0 difference in diopter adjustment
___________________________
" How to Convert Diopters to 20/20 Scale?
Now you have understood what 20/20 vision means, it does not translate to the prescription that your optometrist will pass to you for your glasses.
While the 20/20 vision system measures how well you can see compared to a healthy benchmark, diopters measure the focusing power of your glasses.
The prescription is measured in diopters, the refractive power of your new glasses or contacts.
You will get a separate diopter value for each eye. If the measurement has a minus (-) before it, you are myopic and if there is a plus (+) before it, you are hyperopic.
There is a relationship between the two, shown in the table below.
20/20 Measure In Feet 20/20 Measure in Metres Estimated Refractive Errors in Diopters
20/20 6/6 0
20/30 6/9 -0.50
20/40 6/12 -0.75
20/50 6/15 -1.00
20/70 6/20 -1.25
20/100 6/30 -1.50
20/150 6/45 -2.00
20/200 6/60 -2.50 ---- K 3 max
20/250 6/75 -3.00
20/300 6/90 -3.50 ------- K 1 max
Diopter Conversion Chart
The right-hand column is given approximately as there is not a rigidly fixed relationship between refractive error and visual acuity.
Two people who have the same refractive error and need the same prescription may have widely different degrees of success in reading a distant wall chart with their glasses removed.
It is included here merely for information purposes. "
What Is 20/20 Vision? How Convert Diopters To 20/20 Scales
