03-20-2019, 02:37 PM   #16
I wonder if SS on K-3 vs K-3 II and K-1 vs K-1 II is improved.
Pentax engineers are certainly aware of SS, as they are of mirror bounce (particularly with the K-1), so one would expect to see modifications/tuning of this as bodies are refreshed. And how does the newer KP compare with K-3 II?
FWIW, when I first used Sony NEX mirrorless (NEX-5 and NEX-F3), I was mildly shocked how much the body shook when the shutter was fired. It was a kind of double motion backwards and forwards, and then a very vibrant snap. Things have improved a bit with later Sony's, but you certainly still feel it. I guess that makes me more tolerant of what's going on with K-3/K-1. The Pentax engineers have done a good job taming the shutter, particularly acoustically.
03-20-2019, 02:49 PM - 1 Like   #17
Otis Memorial Pentaxian
My experience following posts on this site is that those who are looking for shutter shock will find it. That does not mean it is a fantasy, only that there may be limits to cancelling the effect of moving mass and the tendency for cameras, lenses, and camera supports to harbor resonance. A short list of potential sources for minor camera movement (both immediate and resonant) include (assuming reasonable time between exposure):
  • AF action
  • Shutter button depress
  • Lens aperture movement on stop-down
  • First curtain start
  • First curtain stop
  • Second curtain start
  • Load at tension
  • Ground movement
  • Air movement (I have heard a tripod hum)
The last two specifically involve tripod-mounted shooting. The third from last is potentially the most troubling.
(...not going to elaborate...)
03-20-2019, 03:15 PM - 1 Like   #18
Why would't you adjust the aperture and ISO in order to avoid these shutter speeds when using the lenses that are effected by shutter shock?
03-20-2019, 03:26 PM - 1 Like   #19
Senior Moderator
BigMackCam's Avatar
QuoteOriginally posted by BROO Quote
I think the point is not that the problem can't be worked around, but that it exists in the first place and may even have coloured some folks' views of lens performance, when it's really just an unfortunate bi-product of mechnical shutter operation
I agree with @stevebrot above... If you look for it, you'll find it. It's potentially more prevalent than we realise - but most of the time, we don't realise it or, because of our personal tolerances or image reproduction sizes, don't care too much...
03-20-2019, 03:36 PM - 1 Like   #20
Wingincamera's Avatar
Reminds me of the motorcycle forums I read. If someone posts a possible problem, everyone immediately wants to check their bike for a problem they never saw before.
03-20-2019, 03:45 PM   #21
QuoteOriginally posted by Wingincamera Quote
Shutter shock is nothing new. Best to know how your camera and lens combination is affected by the shutter speed and then work around it. I think that is what good photographers do?
03-20-2019, 03:47 PM   #22
QuoteOriginally posted by BarryE Quote
So here's what I found from multiple tests, using two K-1 s, and using a variety of hand-held techniques/positions. On all of the following lenses I repeated the tests using my normal tripod/MUP/remote set-up as a base - it was completely consistent -no instances of shutter stock were experienced using the tripod.
At face value, one might question some aspect of hand-held technique with lighter kit, since the common denominators are small-light lenses hand-held. This is not a judgement on experience or technique, only an observation. Do you have example photos?
03-20-2019, 03:50 PM   #23
Senior Moderator
BigMackCam's Avatar
Moved to Pentax K-1 forum...
03-20-2019, 04:06 PM - 1 Like   #24
Senior Moderator
BigMackCam's Avatar
Right, and that's exactly what the OP is doing. He's just recently noticed the effect with this particular lens and camera combo (because, let's face it, it doesn't happen with every lens and camera in the same situations) and now he's having to figure out ways to work around it, whilst also wondering if it has bothered anyone else with the same combo...
03-20-2019, 04:14 PM   #25
Academic I know, but my testing of the shake problem found it to be shutter induced, not mirror. Using the MLU option had zero effect on the shake.
My testing led me to conclude what I wrote here, and so far so good I don't have blur problems anymore. So, maybe some cameras behave differently then mine. Important is that we find ways that suit us the best. What is often mixed up with shutter shock is in fact camera shake more pronounced with small lenses.
03-20-2019, 04:18 PM   #26
Yes I did read the OP.
That's why I suggested adjusting the ISO and aperture for particular combinations of camera and lens. That is what good photographers do. Nothing new here. Potentially every camera/lens combination has its own harmonic frequency sour spot. A good photographer knows their equipment. The OP is correct and doing the right thing but you need to know how your individual camera lens combination works.
03-20-2019, 04:22 PM   #27
StephenHampshire's Avatar
Here are a couple of shots typical of my kind of shooting....not really practical to drop shutter speed (subject in motion) and the ISO is high enough s it is (low light) The FA35 and FA43 are my staple low light lenses on the k1!
FA35, 1/100 F2.5 ISO16000
FA43 1/60 F2 ISO 10000
03-20-2019, 04:24 PM   #28
A moving subject in the dark and its a bit soft? The last thing I would be doing is blame my equipment!
03-20-2019, 04:30 PM - 1 Like   #29
Senior Moderator
BigMackCam's Avatar
You keep mentioning what a "good photographer" does or should do, and I guess that's what prompted my last reply, and this one. It might not be your intention, and I may be unique in interpreting this, but it sounds like you're not sure (or questioning) if the OP is a "good photographer". In my view, he's noticed an issue, isolated it, is interested that it's happening with his particular camera and lens combo (because, as I said before, it doesn't happen with all cameras and lenses in the same circumstances), asking if others have experienced it with his specific combo, accepting he will have to adapt, and doing us all a service by relaying his experiences here. All of which strikes me as "good photographer" material in anyone's book - would you agree?
03-20-2019, 04:30 PM - 2 Likes   #30
I'm not, just pointing out that you can't always easily avoid the risky shutter speeds! The K1 and FA35 is my absolute favourite combination!
camera, cameras, dslr, effect, full frame, full-frame, images, k-1, k-mount, k1, lens, lenses, mass, monopod, pentax k-1, pentax lens, range, reduction, shock, shutter, shutter shock, slr lens, system, times, tripod, wonder
Carbon Fiber Tripods and shutter shock DSLRnovice Pentax Camera and Field Accessories 19 02-23-2019 10:41 PM
Shutter shock blurring Pikselisiirto Pentax K-1 13 10-02-2018 07:29 AM
live view and shutter shock johnkrumm Pentax K-1 6 12-16-2017 01:05 AM
K-1 + DFA 28-105 mirror slap / shutter shock etc awscreo Pentax SLR Lens Discussion 20 05-25-2017 09:23 PM
(The Big shock) CANON 7D - NIKON D300S & PENTAX K-x ISO PERFORMANCE (The Big shock) starscream Pentax DSLR Discussion 21 01-14-2010 05:17 AM
All times are GMT -7. The time now is 10:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
