04-24-2019, 01:30 PM   #31
There is actually a trick to make it work with AF lenses, but that's not for the faint hearted...
You don't even have to activate CIF for this hack, in fact...
In standard af mode (focus priority, af on shutter button), just press on the lens release latch with your ring finger prior to focusing... the motor will turn without engaging the lens, and the camera will only expose when proper focus is detected...
Added bonus: you can still select the af point !
Another way, iirc, is to transform your af lens into a mf one by using some thin tape... not an on-the-fly solution, obviously... but I'll have to check this one again...
---------- Post added 04-24-2019 at 10:55 PM ----------
Ok, I've checked, and the only way to make the tape trick to work is by taping the af coupler. This has the same effect as pushing on the lens release latch while focusing, as the af motor will turn without engaging the lens...
04-24-2019, 05:02 PM   #32
Otis Memorial Pentaxian
QuoteOriginally posted by dlacouture Quote
Of course, doing the rotation hack will also trick the camera into thinking it cannot control the aperture, which is quite true; in fact the aperture will be partially stopped down as part of the hack. I thought the wrong hack but still don't recommend running having the AF pawl running free a few millimeters off its lens-side coupling.
(...I would only do this on a camera or lens I don't care to use again...)
04-24-2019, 05:03 PM   #33
If that is what you found, then you were not taping the correct contact. I have done the tape trick, but only on a lark. I have plenty of lenses that work well natively using CIF, in the rare case when I need it.
04-24-2019, 05:19 PM - 1 Like   #34
QuoteOriginally posted by Oakland Rob Quote
I wonder why they limited it to manual focus lenses.
They didn't. CIF was an accidental side-effect (a happy bug) of AF-S (focus priority) fail-over behavior* that was user-discovered back in 2007 by both Pentax and Nikon users (behaviors are similar). It was later incorporated as a configurable option for both systems.
* Fail-over for the case where the AF/MF button is on AF, but with a manual focus lens mounted.
af, button, camera, catch-in focus, dslr, focus, full frame, full-frame, k-1, k1, latch, lens, menu, motor, pentax k-1, press, priority, release, screen, trick
Catch in focus, live view doesn't catch Oktyabr Troubleshooting and Beginner Help 4 02-24-2019 12:44 AM
Mark's K-1 II discovery thread MarkJerling Pentax K-1 49 11-29-2018 01:58 AM
Nature Grizzly - Wolf Discovery Center outside Yellowstone dwalt Post Your Photos! 3 08-13-2018 12:39 PM
How to use Trap-focus or Catch-in focus eurostar Pentax DSLR and Camera Articles 34 07-22-2017 08:29 PM
Focus Trapping (aka Catch-In Focus) regor Pentax K-01 7 01-05-2013 11:32 PM
All times are GMT -7. The time now is 01:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
