08-03-2019, 06:01 AM   #1
Back button focus + AF Select workflow
I found that with BBF (in AF2 mode, disabling shutter half press focus), you have to first lock meter with AE-L if your subject isn't centered.
Then the whole workflow will become:
(Given center-weighted AE is my default)
1) Center subject and meter with AE-L
2) Re-compose
3) Put AF point on subject
4) Press AF
5) Shoot
or Link AE-L point with AF point, then:
1) Compose
2) Put AF point on subject
3) Press AF
4) Shoot
I'm interested in hearing how do you do it?
08-03-2019, 06:32 AM   #2
For me moving AF points is too slow for shooting moving subjects, I only use AF point selection for macro. I'd use center focus and recompose, letting camera AE to expose for the scene instead of subject only. Link AE to AF point work for point AE, not so much work with center weighted metering, center weighted AE is center weighted regardless of the AF point selected.
08-03-2019, 06:36 AM   #3
Use AF-C with BBF and focus as needed. This gives you a lot of options and allows for quick changes.
For AF-S the whole thing has little advantage.
08-05-2019, 07:02 AM   #4
One other option would be detach AE-L from AF lock, use multi Multi-segment. If you are using a K3 it's pretty accurate.
Focus what you want, either by focus recompose or AF-sel, and let the camera meter by averaging the scene.
If the subject you are trying to capture are to much dynamic, locking exposure might lend to exposure error.
Or, if it is more or less static, you can shot manual, use green button to snap the exposure and shoot whatever focus mode you like.
So many options.
08-05-2019, 08:57 AM   #5
Otis Memorial Pentaxian
QuoteOriginally posted by sungibr Quote
Excellent idea in general.
ae-l, af, button focus af, dslr, focus, full frame, full-frame, k-1, k1, meter, pentax k-1, press, subject, workflow
Disable green button for back-button focus? Igor123 Pentax K-1 7 06-03-2019 08:01 PM
AF Spot mode: hidden fact revealed - AF point is 30% smaller than in "select" beholder3 Pentax DSLR Discussion 17 09-14-2018 12:15 AM
Request feature: AF point select using a button on the body and one scroll dial howieb101 Pentax K-1 14 04-01-2016 02:20 AM
K5 Foibles (?): Memory card, shake reduction, mode select lock-out button AstroDave Pentax K-5 19 05-17-2011 12:58 PM
A More Precise Workflow & Sharpening Workflow benjikan Digital Processing, Software, and Printing 2 06-01-2007 06:07 AM
All times are GMT -7. The time now is 04:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
