09-25-2019, 05:09 PM   #1
autofocus setting question K-1ii
Hi-
I'll do my best to describe what's happening...
I have a K-1ii. Normally I have AF set to auto, in the center (9 middle squares). When it's set to this, I keep bumping the arrow buttons on the camera body, thus moving the AF left/right/up/down.
The only way I have found to avoid this is to set AF to Auto, but with all of the squares highlighted- on this setting, the arrows switch to something else.
Is there a way to set AF to auto in the center, which I prefer, but disable the arrow keys from moving the focus point unless I push something other than the arrow to move it?
Does it make sense what I'm asking?
Thanks.
09-25-2019, 05:20 PM   #2
MarkJerling's Avatar
Yes, it does make sense. On the rear of your camera, you'll see a button that functions as follows:
If you don't have it set to AF point change mode, you should not experience this problem.
09-25-2019, 05:21 PM   #3
pschlute's Avatar
Press the button immediately above the 4-way controller.
09-26-2019, 01:34 AM   #4
Though if you're changing the AF position you'll also be bumping the WB and other buttons.
You can use the Spot autofocus mode which sets the focus point to the central focus point only.
This is in the manual, page 52
af, arrow, auto, center, dslr, full frame, full-frame, k-1, k-1ii, k1, pentax k-1, squares
Update from K-3 to K-1ii, observations Jacobus2 Pentax K-1 4 08-25-2019 08:26 AM
K-1ii the third most popular camera on Imaging Resources. normhead Pentax K-1 6 01-25-2019 05:36 AM
Focus Issues with TAMRON 28-75 2.8 AF on K-1ii Merv-O Pentax K-1 21 11-16-2018 12:20 AM
Strange Pentax K-1ii deal on Amazon jumbleview Pentax Price Watch 3 05-26-2018 12:57 PM
K-1ii manual? Oakland Rob Pentax K-1 7 04-16-2018 01:01 PM
All times are GMT -7. The time now is 04:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
