Originally posted by kiwi_jono I have an electronics background and I have thought of doing my own DC power adapter also but be aware if something goes wrong it is all too easy to fatally damage a camera if something goes wrong (like full 12+ VDC gets passed through to the camera) - also voiding any warranty.
So far I have not been brave enough to do this with my K-1 and agree it would certainly be great if Pentax provided a DC adapter as an accessory.
Kiwi_jono is quite correct. Series regulator chips have been known to fail, putting the full unregulated voltage on the load. Toasting a K-1 would really, really hurt. Any power supply should include what's known as a crowbar circuit (Google for examples) which basically puts a short across the supply output if it goes over the specified voltage, thus preventing damage downstream. An experimenter can start with a three pin regulator like that mentioned, and add a crowbar circuit pretty easily. Even two back-to-back Zeners (with appropriate power ratings) with breakdowns just above the desired voltage and a line fuse preceding them would be effective in preventing overvoltage getting to the camera load. The latter is desirable even with a crowbar since it provides transient protection should something happen to introduce a power transient in the line.
A fake battery can be 3D printed with provisions for camera contacts and a power lead which goes to an external regulator circuit. Of course, the battery compartment door needs to remain open for this arrangement which is inconvenient and risky (to the door). Some cameras have a power connector (plug-in jack) which gets around the issue of going in through the battery compartment.
