10-16-2019, 03:45 PM   #1
K-1 Lag
Well, I don't think I've seen anyone mention this, so here goes:
I find myself quite frustrated, quite often, by wake-up lag on my K-1 Mark II and I'm convinced I'm missing more shots as a result than I ever did with my K5. When the camera goes to sleep even viewing a photo is frustrating - I first push the Play button and then wait a couple of seconds while the camera wakes up (with the activity LED flashing) and then press the play button again to actually view a photo (pressing it once only wakes the camera up, it will not, without another button push, display a photo).
I haven't used a stop-watch, but qualitative comparison between the K-1 and the K5 (wake-up to shutter fire) seems significant. More than a second for K-1 and less than a second for K-5.
I love the camera, but this is an irritant. That and the number of button pushes required to turn off the Info display...
Now I'm going to run for cover!
10-16-2019, 03:48 PM - 2 Likes   #2
First of all, are you using a UHS-I memory card? Second, AFAIK the correct way to wake the camera is to half press the shutter. Doing so and then pressing other buttons may thus yield a faster response. Third, maybe increase the delay before the camera goes to sleep so that this doesn't interrupt your photo viewing?
10-16-2019, 04:18 PM   #3
kiwi_jono's Avatar
^^^ This for sure. I have tried on my K-1 and the Play button adds additional time as it loads some images to view. Half push of shutter is faster. I also have a longer sleep time set.
10-16-2019, 06:58 PM   #4
Ex Finn.'s Avatar
Just tried it here also. Wake-up time is adequate IMO, it has to access the card after all. Seems that my KP might be a tiny bit faster.
10-17-2019, 06:07 AM   #5
jab2980's Avatar
If you're in a situation where you're missing shots, I'd recommend extending the duration before your auto-off kicks in. I'm pretty sure mine is set to 30 minutes.
10-17-2019, 10:31 AM   #6
Crooski's Avatar
Strange The camera does not go into sleep mode when I am viewing photos
10-18-2019, 07:15 AM   #7
Were you viewing photos and left it alone for 1 minute? Or whatever your auto-off was set to? I could see it do that if you left it alone long enough.
But if you were going through photos faster than you auto-off time, then I would not expect it to power off. Now maybe the screen would go black, but not power off.
button, camera, dslr, full frame, full-frame, k-1, k1, k5, pentax k-1, photo, play, wake-up
Shutter Lag - K-3 and K-1 measurements AstroDave Photographic Technique 10 01-25-2019 03:48 PM
Nikon Z7 mini-display (1,2 MPx "EVF") joy ... blackouts, lag etc. beholder3 Canon, Nikon, Sony, and Other Camera Brands 12 08-31-2018 11:28 PM
Mouse lag affecting Lightroom among other things Bruce Clark Digital Processing, Software, and Printing 5 06-26-2018 05:26 AM
K-1 shutter lag increase with MLU / Mirror Lock Up JensE Pentax K-1 & K-1 II 11 01-19-2018 11:15 AM
pentax k1 with shoe mount pttl flash, shutter lag? ontariomark Pentax K-1 & K-1 II 10 05-08-2016 08:44 PM
All times are GMT -7. The time now is 04:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
