11-08-2019, 05:54 AM   #16
However, I had my K1 upgraded
IMO, the K1 upgrade of the mother board is not exactly the same as buying a K1 Mk II from Ricoh factory line. Or... my K1 is a deviation from the K1 standard quality , explaining why some K1 users noticed shutter shock and other didn't with the copy of K1 they own, also possible.
11-08-2019, 11:31 AM   #17
Mikesul's Avatar
IMO, the K1 upgrade of the mother board is not exactly the same as buying a K1 Mk II from Ricoh factory line....
This seems likely since the factors causing shutter shock are unlikely to involve the parts replaced in the upgrade. If the SS went away after the upgrade it might just be that reassembly tightened or loosened something which eliminated the problem.
11-08-2019, 01:01 PM   #18
My K1 mark II is not a K1 upgrade. I have two bodies, one K1 and one K1 II, both purchased new from Ricoh, I have compared the same images taken with both bodies and the same DFA28-105 lens, K1 images are blurred, K1 II images aren't blurred. So there is something with the shutter block of my K1 that's not the same as the shutter block on my K1 II. My K1 makes a more distinct shutter noise than my K1 II, the K1 II sound is softer.
11-08-2019, 05:56 PM   #19
jatrax's Avatar
Have you investigated sending it in for "repair" or adjustment? It would seem there is something different about your K1. Mine was a pre-order so presumably out of the first production batch. Just curious what Ricoh would say about sending it in for this.
11-08-2019, 10:10 PM   #20
I've decided to use the K1 with heavier glass (DFA150-450) shutter speed is almost always faster than 1/200th, and use the DFA28-105 on the K1 II.
dslr, full frame, full-frame, k-1, k1, pentax k-1, shock, shutter
Shutter shock format dilemma biz-engineer Photographic Technique 45 10-29-2019 10:20 AM
Shutter shock with small primes BarryE Pentax K-1 62 10-20-2019 11:16 PM
K-1 battery grip - does it fix the shutter shock issues with the DFA 28-105? awscreo Pentax DSLR Discussion 11 10-22-2017 03:16 PM
K-1 + DFA 28-105 mirror slap / shutter shock etc awscreo Pentax SLR Lens Discussion 20 05-25-2017 09:23 PM
(The Big shock) CANON 7D - NIKON D300S & PENTAX K-x ISO PERFORMANCE (The Big shock) starscream Pentax DSLR Discussion 21 01-14-2010 05:17 AM
All times are GMT -7. The time now is 03:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
