11-20-2019, 02:13 PM   #1
sculptormic's Avatar
Pentax K-1 + samyang 24 TS lens question.
Just bought myself the Samyang 24 TS lens because I need it. I would like to use it in combination with Pixel Shift.
I hope some more experienced shooters of this combination can help me out.
The problem is when I use shift I can not reach Pixel Shift in the Info menu.
I used PS in the past with the 28 Pentax shift lens.
I could take a few PS images using shift but after that PS was no longer on and when I tried to reach it in the info menu it
was skipped as if it was not here. The icon is still there but it is skipped when I scroll through the menu.
Do I have to do it in a certain order like for instance before shifting?
When the lens is not shifted I can put it on AV. As soon I shift I have to put it on M. Does that have something to do with it?
M mode by it self is not a problem I just use a light meter.
11-20-2019, 02:50 PM - 1 Like   #2
baro-nite's Avatar
I own both, and have not had this issue. The fact that the icon is disabled at times for you makes me wonder if it is one of the other modes with which PS is incompatible, as per page 107 in the user manual. Then somehow when you switch into M mode you are enabling this incompatible mode. Obviously that is just a guess.
Some of the incompatible functions are:
AA filter simulator
Flash
Continuous shooting
Bracketing
Mulit-exposure
Interval shooting
11-21-2019, 05:29 AM   #3
QuoteOriginally posted by baro-nite Quote
AA filter simulator
Flash
Continuous shooting
Bracketing
Mulit-exposure
Interval shooting
Thank you!
It seems to work now, also in M mode but why I don't know
11-25-2019, 09:47 AM - 1 Like   #4
MJKoski's Avatar
I use Samyang 24mm T/S with K-1. It might have something to do with light metering as liveview metering is only way to meter correctly with any shifted lens on modern camera. Samyang 24mm if fully mechanical without aperture coupling and AE metering does not work for starters. This is where Pentax liveview experience is a bit hit or a miss compared to most MILC options. It should be fixed to simulate exposure with whatever light reaches the sensor regardless the used mechanical aperture. Sony, Fuji, Olympus and Panasonic for example are able to do that. Green button metering is not enough and does not allow histogram in M-Mode anyway without aperture coupling.
combination, dslr, full frame, full-frame, k-1, k1, lens, menu, pentax, pentax k-1, pentax k-1 samyang, ps, samyang 24 ts, shift, ts lens
Looking for local Pentax "expert" Boise, Id Need TS help! Daniel Gamel Troubleshooting and Beginner Help 17 04-14-2018 06:54 PM
For Sale - Sold: Samyang 24mm TS WPRESTO Sold Items 0 04-09-2018 06:51 PM
Pentax 28mm Shift vs Rokinon 24mm TS JamesDCrockett Pentax SLR Lens Discussion 18 02-14-2018 11:38 AM
Samyang 14 2.8 vs Samyang 24 1.4 for Astrophotography reivax Pentax SLR Lens Discussion 17 09-15-2017 01:50 PM
Samyang 24 mm F3.5 TS shipped in December-January. yurko_yr Pentax SLR Lens Discussion 1 10-03-2012 04:37 PM
All times are GMT -7. The time now is 08:37 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
