Hi folks!
I've always noticed that my K-1 normally gives me a colder tone (towards blueish) than for example my APS-C Nikon and Canon cameras do. It's when I compare the images with these other cameras when the cold tone from my K-1 becomes obvious.
Usually Canon's color callibration leans towards the warmer side (better for portraits and social photography), the Nikon's towards the neutral (the "sweet spot") or slightly warmer side (better for nature / landscapes) and Pentax, at least in my experience so far with the K-1, towards the colder (blueish) side, which can be annoying. In my opinion the Nikon callibration is the best one, being the Pentax one too "cold" and "analytical" to my tastes.
I always shoot in JPG fine and have my image / tone setting in "Bright" with default settings (except for Sharpness, set to Fine maximum) and the White Balance set in Auto.
The good news is that few days ago I've discovered that I can change the color cast by editing the white balance (moving the default point inside the color palette to give a desired tone).
As I do prefer a slightly warmer cast on my images (in fact neutral) like my Nikon does, rather than the default cold/blueish tone coming out from my K-1, I did a quick test by editing the white balance, moving the point towards the right (orange) exactly in opposition to the left (blue), in order to counter the cold tone and get a neutral tone (moving the point towards the orange side -the opposite side from the blue- in fact neutralizes the cold/blueish tone).
Have any of you guys noticed this cold/blueish tone coming from your K-1 by default? Have you fixed it and if so how did you do?
I will do more tests (and compare with my Nikon) by shooting with the following settings in "Bright" mode:
- Saturation: 0 / WB: A0
- Saturation: 0 / WB: A1
- Saturation: 0 / WB: A2
- Saturation: 1 / WB: A0
- Saturation: 1 / WB: A1
- Saturation: 1 / WB: A2
("A" is the letter when we move the point towards the right side of the color palette -orange-, so the opposite of blue).
I think the "sweet spot" to neutralize the cold tone is one of those settings above (A1 or A2).
What do you think guys?
