Show Printable Version 22 Likes Search this Thread
01-04-2020, 03:48 PM - 6 Likes   #1
Fenwoodian's Avatar
You Don't Need A Scanner When You Have A Pentax K-1
15-years ago I scanned most of my medium format slides on an expensive Heidelburg flatbed scanner. The scanner broke down and I never did get around to scanning my 35mm slides and print negatives.
A fews weeks ago I purchased and inexpensive Nikon ES-2 Film Digitizing Adapter. I finally got around to using it to scan my ancient 35mm slides and negatives.
I used the below Vivitar macro M42 lens on my K-1. I've tried many macro lenses, and in head to head tests, this lens was found to be the sharpest macro that I tested. In fact, when properly focused, I can see individual film grains in the slides. This lens has a 62mm filter thread, which is needed for the Nikon ES-2. You can probably use other macro lenses, but you would need an adapter if the front filter threads are not 62mm.
Taking photos of the slides was easy. However, it took a considerable amount of experimentation to nail the best settings for shooting the negatives.
Once I got the hang of it everything went pretty quickly, and the results were better than I had expected.
Below are the K-1 settings that I ended up using in case you are interested:
1. Slides - large jpg files, APS-C crop, natural color setting, ISO 1600, no IBIS, f/4.5 , 1/90th
2. Negatives - large jpg files, APS-C crop, digital filter set on "Invert Colors", flat color setting, no IBIS, ISO 1600, f/5.6 (not as flat as slides), 1/10th second
I'm not sure APS-C Pentax cameras have a digital filter setting that can be set to "Invert Colors". You need this setting in order to shoot the negatives.
Also, the young boys in the below photos are my sons - they're all in their 40's now.
01-04-2020, 04:09 PM   #2
tvdtvdtvd's Avatar
How did you illuminate the slides?
01-04-2020, 04:39 PM   #3
Fenwoodian's Avatar
QuoteOriginally posted by tvdtvdtvd Quote
Held the end about 4 - 6 inches away from a dining room light fixture. Used average white balance.
01-04-2020, 04:46 PM - 1 Like   #4
2B1
Cheers for posting this.
---------- Post added 01-04-20 at 04:51 PM ----------
Fenwoodian :
Just curios.
Why have you shot the negatives in crop mode and not full frame mode
and is there a reason for using the invert colours settings , in preference to others?
01-04-2020, 05:02 PM   #5
Fenwoodian's Avatar
QuoteOriginally posted by 2B1 Quote
Fenwoodian :
Just curios.
If you don't shoot in crop mode you will need to do a lot of cropping in post.
Only the "invert colors" mode will work on negatives. The only other option that I can think of would be to invert colors in post, but I don't know how to do that.
01-04-2020, 05:08 PM - 1 Like   #6
pres589's Avatar
You can create a tone curve invert preset in Lightroom to do a straight inversion. Negative Lab Pro is a plugin like Nik Collection that works with Lightroom and it's how I do my negative copying with my DSLR. I like the results I get, and arrive at faster, using Negative Lab Pro.
I've heard good things about that 55mm f2.8 Macro. I'm using a Kino Precision 105mm Macro and a K-5 II for DSLR negative copying. Still have to do some cropping but that allows me to be slightly less than perfect in my placement of the negative.
01-04-2020, 06:01 PM   #7
sergysergy's Avatar
very nice. Out of curiosity, does the aperture number make a big difference?
01-04-2020, 06:59 PM   #8
Not a Number's Avatar
Looking at the user instructions it seems the attachment is designed to be used with the Micro Nikkor 40mm AF-S DX (crop) or the Micro Nikkor 60mm AF-S/AF. The attachment is screwed directly to the 40mm or uses the short (A) or long (B) adapter for the 60mm AF-S or AF, respectively.
I wonder how this attachment would work with the Pentax 35mm DA macro on a crop body or crop mode on the K-1.
Have you tried it with the short (A) adapter on the Vivitar lens?
Long ago Pentax made a similar slide holder for use with 50mm lenses (either macro or a normal lens with tubes):
PENTAX Slide Holder 1x, K reviews - Pentax Camera Accessory Review Database
01-04-2020, 07:37 PM - 2 Likes   #9
jumbleview's Avatar
QuoteOriginally posted by Fenwoodian Quote
Only the "invert colors" mode will work on negatives. The only other option that I can think of would be to somehow figure out how to invert colors in post, but I don't know how to do that.
Here is the tutorial of how to invert negative in lightroom
I do not have Adobe subscription but I tried the same with GIMP. Works approximately the same.
01-04-2020, 08:52 PM   #10
ismaelg's Avatar
Thanks for posting this!
I got a M50 f4 macro with this purpose in mind , but haven't complete the setup yet.
Thanks,
01-04-2020, 10:16 PM   #11
BigDave's Avatar
Excellent technique, thanks for sharing!
01-04-2020, 10:43 PM   #12
Fenwoodian's Avatar
Great question. Yes I have - it's just a tiny bit too short to achieve good focus.
01-04-2020, 11:49 PM   #13
Good results, don’t suppose anyone ever made one of these for 6x6 negatives?
01-04-2020, 11:59 PM   #14
Fenwoodian's Avatar
QuoteOriginally posted by hypermodern Quote
Not to my knowledge.
Please note that the b&w portrait I posted above was made from a 6x6 Hassy medium format negative. I trimmed it down a bit with a scissors to fit into the 35mm sized negative carrier. Would you consider that to be "radical cropping"?
01-05-2020, 12:14 AM   #15
Please note that the b&w portrait I posted above was make from a 6x6 Hassy medium format negative. I trimmed it down a bit with a scissors to fit into the 35mm sized negative carrier. Would you consider that to be "radical cropping"?
Trimmed, as in with scissors?!
aps-c, color, crop, dslr, full frame, full-frame, k-1, k1, mode, negatives, pentax k-1, scanner, settings, slides
Is the K1 a foolish choice if you don't have any modern glass ? rjm007 Pentax K-1 & K-1 II 77 08-24-2018 11:30 AM
Abstract When you have to shoot, shoot, don't think. gump Post Your Photos! 8 08-19-2018 05:38 PM
Food You don't always need a fancy DSLR to capture what you like Pentax_WA Post Your Photos! 2 09-15-2017 11:30 AM
Money I don't have on things I don't need daacon Pentax SLR Lens Discussion 5 12-13-2007 10:04 PM
After all you invested and you DON'T have a monitor calibrator? slip Digital Processing, Software, and Printing 38 04-01-2007 03:55 PM
All times are GMT -7. The time now is 02:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
