01-21-2020, 12:00 PM   #1
amstel78's Avatar
SR badge fell off
Just noticed the other day that the little SR badge on the front of my K1-II disappeared. Has it happened to anyone else? I use heavy lenses on the K1 with a grip and sometimes when holding it, my fingers end up right on the spot where that badge used to be. I guess after some time, it just fell off; never to be seen again...
01-21-2020, 12:35 PM - 6 Likes   #2
amateur dirt farmer
pepperberry farm's Avatar
maybe you shook it too hard?
01-21-2020, 12:40 PM   #3
Not a Number's Avatar
Is that an upgraded K-1 to K-1ii? On the upgrades the SR badge is replaced with a K-1ii one. Another member reported the replaced badge falling off.
01-21-2020, 12:41 PM   #4
amstel78's Avatar
QuoteOriginally posted by pepperberry farm Quote
Nah, I think the pressure from my fingers rubbing against the badge just loosened the adhesive to the point it fell off. There's a flat area on the rubberized portion of the grip where it used to be. It still had remnants of a thin double-sided adhesive stuck to it where the badge should have been.
No big deal really; just wanted to point out to the forum that they might come off unexpectedly.
---------- Post added 01-21-20 at 07:42 PM ----------
No, this is a genuine K1 Mark II.
01-21-2020, 03:00 PM - 6 Likes   #5
AggieDad's Avatar
You will have to be extra careful to everything steady now that you no longer have shake reduction.
01-21-2020, 04:10 PM - 1 Like   #6
I worked in manufacturing for 35 years. Adhesives is a very deep and broad subject, with many different chemistries. There are weak adhesives (think post-it notes and painter's tape), strong aggressive adhesives used to hold cars and buildings together, and everything in-between. I've lost track of how many peel-and-stick consumer products I've been disappointed with. Perhaps Pentax unwittingly bought the SR badge labels from a vendor using a low quality adhesive. There are certainly some adhesives that would be stronger than the badge material itself, but of course they cost more.
01-22-2020, 01:12 AM   #7
Chris_K's Avatar
I lost mine from K-50. Found it, used cyanoacrylate adhesive to fix it in place - has been good for the last 2 years.
01-22-2020, 09:33 AM   #8
Probably a QA issue - bad/different batch of adhesive, contamination on the area for the adhesive to bind to, or insufficient pressure on the badge to get it to bind.
01-22-2020, 04:33 PM   #9
QuoteOriginally posted by amstel78 Quote
Dang. You mean my upgraded K-1 isn't genuine?.....
01-22-2020, 06:16 PM - 1 Like   #10
amstel78's Avatar
QuoteOriginally posted by clickclick Quote
Nope. It's an imposter.
---------- Post added 01-23-20 at 01:17 AM ----------
QuoteOriginally posted by Chris_K Quote
I would have done the same if I could find it. But it either fell off outside or the cat ate it.
01-22-2020, 07:29 PM   #11
monochrome's Avatar
QuoteOriginally posted by Apet-Sure Quote
Sometimes itís just sketchy design decisions. The Mode dial on the K-01 - a very nice bit of milled aluminum - was attached to the selector shaft with a dab of rubber cement. (OEM spares run $45 on e Bay).
01-23-2020, 01:04 AM   #12
Consider it as a battle scar. We get scars over time so do cameras. Nothing lasts forever. Keep shooting until it completely falls apart and disintegrates.
badge, dslr, full frame, full-frame, k-1, k-1ii, k1, pentax k-1, sr, sr badge
Tokina, king of badge engineering Mistral75 Photographic Industry and Professionals 15 01-17-2020 02:01 PM
Machinery Old Cadillac badge bobbotron Post Your Photos! 4 01-12-2020 07:13 PM
Abstract Caddy Badge ToddK Post Your Photos! 9 12-18-2019 06:23 AM
Should SR noise occur when SR is off? amoringello Pentax K-5 5 11-29-2010 06:03 PM
SR Tag Fell Off Of Kx seachunk2 Troubleshooting and Beginner Help 3 11-08-2010 07:57 PM
All times are GMT -7. The time now is 11:25 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
