Originally posted by sbh Shooting in jpeg only:
JPEG L * * * => 29 shots
JPEG XS * * * => 31 shots
JPEG XS * => 31 shots
JPEG L * => 41 shots
No. 14 shots until slowdown for both on my K-1. But cropping to APSC speeds up the framerate and goes up to 52 shots until slowdown.
I did some quick testing in FF mode. In RAW, the buffer can only take a certain amount of data until it's full. For example: I can take 13 shots at 1/250 or 23 shots at 1/8 until the frame rate drops. However, the 13 shots at 1/250 take 3 seconds and the 23 shots at 1/8 take over 6 seconds. Both equal roughly 4 frames per second.
In JPEG I get 45 frames at 1/1000 until the frame rate slows down and seemingly endless shots at 1/250 and 1/30 (I stopped at around 350 frames).
Turning on lens corrections (fat fifty) slows down the frame rate to approx. 1 fps starting with the first frame.
Thanks for doing that, much appreciated. You missed my one point however;
I already knew that selecting 1:1 for RAW makes no difference compared to FF, that is because (as I said) that the crop is not really 'real'. Taking a 1:1 RAW file to LR will show the crop section, however taking the same 1:1 RAW to RawTherapee for example can give you back the crop areas, proof that at the time the shot was taken it's still collecting the data from the cropped area.
I'm curious in Jpg mode if when acting in 1:1 if there is a similar performance boost like using the APSC crop mode, i.e. I doubt we can claw back the cropped areas from a Jpg version of the file... but I could be wrong, so I need to test that.
My take away message from the tests you have performed here is the following;
1) There exists a sweet spot for optimum/maximum amount of shots grabbed, it relies on some boosting of ISO at times. For example if taking slower shutter shots you can have the ISO low (1/30, ISO 100, under good conditions you can expect to get over 100 shots. But if pushing the shutter speed up to 1/250 you may need to boost the ISO to compensate, thus still getting a high amount of shots (100+). However there is certain shutter speed regardless of reasonable ISO given (1600 with 1/1000) that will result in quite a dramatic cut off (45shots), so shutter speed seems to be quite instrumental in determining how many shots can be taken in succession before reaching buffer. If someone wanted a very long burst session then we ought to keep an eye on the shutter speed and not let it rise too high.
2) Switching from L to M, S or XS has little impact on performance, probably to do with the fact its still recording data from the entire sensor (rather than crop and possibly 1:1, in jpg mode that is). However dropping IQ (*'s) does have an impact. The only question left now is that if the amount of shots obtained are similar between Jpeg L *** and Jpeg XS ***, does the buffer recover quicker once you hit it? I'm thinking it would simply be due to smaller files collected from the XS shots than L? So if you're happy to shoot M (22mp instead of 36mp) you might not get any more shots in the burst, however in theory the buffer will recover quicker?
Originally posted by stevebrot You are in good company. Many of our users are not native English speakers and many use a translation service when posting here. @Brucebanner was just saying that the translation was not very good. I was also a little confused until I saw you are in Riga and might be a Russian or Latvian speaker. Our conversations here are generally pretty friendly and not as rough as some of the eastern Europe forums.
I can only guess how this comment translates back into Russian!
yes I was going to say that I think this was purely language barrier related.
