Originally posted by BruceBanner I was going to ask if RT could split the files up, can I ask how you managed that feat?.........................
You’re probably better off with your approach since you mentioned LR can't handle TIFs, but in
case you want to give HDR sub-image separation a go with RT, do the following after opening
RT on your machine.
Open the RT browser and import your HDR RAW file (around 125MB with a K-1 for 3
bracketed shots) by double-clicking on the file thumbnail. It should open in the Editor window
(note only one of the HDR sub-images will display).
1) In the upper right of the RT Editor window (see photo 1), you have options for
processing. Choose RAW (alt+r) and the drop-down should show a "Demosaicing"
group. Choose an option for demosaicing the Bayer layer (I use AMaZE but you can
choose your own - this is also where you choose pixel-shift demosaicing if it applies).
2) Directly below that is a listing of the "sub-images" which should show numbers
corresponding to those contained in your HDR file. This control allows you to select each
of the HDR sub-images individually (allow a short time for the display to process and
update after changing that selection-blue progress bar at the bottom left).
3) You’re now ready to select each sub-image individually and send it to the queue (see
photo 1 - lower left gear wheel icon). Once you have done this for all sub-images, go to
the queue (Photo 2) and make sure they’re all there. Choose where you want to export to
and the type of files you want to export. Files can be saved as 8 bit or 16 bit TIFs or
PNGs, or JPEGs representing the individual sub-images, ready for HDR processing in
the HDR program of your choice. (I use Photomatix but there are others available).
4) Click on the top left arrow and exporting begins. The thumbnails will disappear as they
are processed and exported (processing doesn’t apply here unless you’ve specified some
particular processing for each sub-image).
There are probably other faster ways to do this, but I have access to these programs so the work-
flow is a good one for me and the results are good. Hope this helps Bruce.
