07-19-2020, 12:26 PM   #1
astrotracer problem
Hello - some assistance please with astrotracer [new to this feature].
I am pretty sure I had this all set to work:
BULB, turn on GPS, Turn on AT, Calibrate AT. Turn on the compass screen.
It either is not working or I am missing something.
The little satellite icon stays red. It will not turn green as indicated. I have started the process over several times... no green icon.
Also, the camera will not shoot. When I depress the shutter button, nothing happens. The screen goes out, the GPS light goes out.
Can someone help me get the satellite icon to turn green?
thanks a bunch! dw
07-19-2020, 12:35 PM   #2
what camera?
07-19-2020, 12:43 PM   #3
Aaron28's Avatar
try turning on gps and wait for green acquisition on a standard display.....once acquired 'green' then proceed to bulb, AT and fine calibration
maybe a weak battery? and sees unlikely the compass screen would affect things as thats what it all about.......
07-19-2020, 01:08 PM   #4
Grimmus's Avatar
Apologies if stating the obvious but just confirming that you are outside with clear view to plenty of sky? I find satellite acquisition usually takes less than a minute. Cheers!
07-19-2020, 01:15 PM   #5
Also, if you are in an area that might have significant electrical interference, you might not be able to get a satellite signal. Best if used where there's less "electronic junk" in the area like the country or an open area away from cell towers, radio transmitters (towers), industrial areas that might have lots of wireless coms, etc.
07-19-2020, 02:14 PM   #6
K1.........
QuoteOriginally posted by bwgv001 Quote
what camera?
---------- Post added 07-19-20 at 02:22 PM ----------
Thanks for the reply. no-go.. The icon stays red, be I am inside or outside
dw
QuoteOriginally posted by Aaron28 Quote
07-19-2020, 02:29 PM   #7
Aaron28's Avatar
QuoteOriginally posted by dr5chrome Quote
dang thats not encouraging news.....hope it's a setting overlooked and not a malfunction or something broke.......
doubtful it's a firmware thing but maybe try a factory reset ??? sorry at a loss......
07-19-2020, 02:57 PM   #8
You are turning on the GPS engine via the small button to the right of the viewfonder hump? Many people do not do this and there is no way you will acquire satellite signal without it.
07-19-2020, 06:29 PM   #9
I think I got it. Took the suggest to get away from buildings.. Turned on finally. :-)) Thanks!
07-19-2020, 06:59 PM   #10
Aaron28's Avatar
good deal !
07-19-2020, 08:08 PM   #11
Glad you got it working. Sometimes, reflections from buildings will confuse the GPS system (phase issues with the signal - can be bad for WiFi too), so happy you found yours working - now to try it out on the real thing...................good shooting!
astrotracer, dslr, full frame, full-frame, gps, icon, k-1, k1, pentax k-1, satellite, screen
Astrotracer and large mm lens OSRags Pentax K-1 15 6 Days Ago 06:05 AM
Nature Astrotracer and the Alps Pete_XL Post Your Photos! 14 10-26-2019 06:44 PM
Why does angle >45 degrees create K-1 Astrotracer trails? crockpotveggies Troubleshooting and Beginner Help 10 07-30-2019 08:08 AM
Astrotracer O-GPS1 strange behaviour Vranx Pentax Camera and Field Accessories 10 09-23-2014 04:47 PM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
All times are GMT -7. The time now is 01:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
