Originally posted by derekkite
If you have the crop set to auto, it will crop it. But there is little vignetting in full frame mode, none that I've noticed in any case. It doesn't focus quite as positively as the 150-450, but not awful.
thank you Derek for the info
---------- Post added 08-27-20 at 01:11 AM ----------
Originally posted by pschlute
As has been said the DA* 300 is a FF optical design and works just fine. Indeed the Pentax software in the K1 has lens correction parameters for this lens in both FF and crop mode.
thanks for the note , im still on the fence on this lens , i really dont want to invest into another 150 to 450 after the last failing me , but im in need of reach
---------- Post added 08-27-20 at 01:12 AM ----------
Originally posted by Billk
It is a FF combination made in heaven. The DFA 200mm F2.8 is also great with the K1.
thank you for commenting Billk
