Originally posted by MeesterP The shutter works normally when the only change I do is turn the knob from "B" to "M"
Does that mean the test below will fail?
1. Set drive mode to single exposure, AF/MF to MF, and exposure mode to M (1s shutter speed). Does the regular shutter work for half and full press? Does the remote work too?
2. Repeat in B mode (no timer set) on your K-1ii. For Bulb type 1, the shutter should remain open as long as the button is held at full press. For Bulb type 2, the shutter should open on full press and remain open until a second full press.
If the AX-5 remote does not work as expected in radio mode, try it with the controller directly wired to the camera using the included adapter cord. Make sure the AX-5 is set for single shot for step #1 and for bulb mode for step #2.
To the best of my knowledge, the wired remote fitting is hard-wired in parallel with the regular shutter button. Placing the plug in the fitting allows the remote to function as a simple switch. The most common problems on the camera side are poor plug fit (not fully seated), something subtle with AF configuration, hardware issues with the remote, or attempting to use a remote that does not use the Pentax plug mapping. There is also the possibility that the shutter is not responsive due to having Slow Shutter Speed NR turned on with the previous exposure being a long one. In that case, the shutter will remain unresponsive until the camera finishes the NR step.
I think you have got me stumped. Perhaps better minds will prevail and be able to give you a solution.
