Lessons learned from today's focus screen debacle are:
1. Don't use sharp tools with optics ever
The metal pointed forceps that
Focusing Screen sends with the screen can damage a screen with minimal force. Be careful, or better yet, use something else.
2. Make sure latches are latched when you latch them.
First installation showed me I needed a shim adjustment, so I installed a shim and thought I had the door latched. I did not. The screen fell out while a lens was mounted, and dismounting the lens somehow created a large s-shaped gouge on the new screen.
3) If it ain't broke, don't fix it.
I didn't really *need* this focus screen. I just read too many positive reviews about it and thought I'd give one a try. The brief few minutes I spent with it didn't exactly impress me as much as the new technique I bumped into after the cleanup of this mess.
4) Isopropyl cleans stuff real good.
Re-installation of the stock screen showed it was dirty. No, actually filthy. I used 70% isopropyl and some Qtips to clean both sides, and problem solved!
[edit] - Turns out IPA might ruin some plastics, so clean distilled water is best for light cleaning, according to just about everyone who commented. That said, 70% did not damage my screen and it did do a good job cleaning.
5) A new technique instead of new gear could be the best option.
I found if I start with the lens focused behind the target, then bring focus past the target thru to the front, then walk the focus back slowly until desired plane is in focus, I can hit the intended target better than just "eyeballing it." I was able to do this a few times with a few objects. Frankly, I think the only way to hit focus faster is with an EVF.
Anyway, I hope this helps someone.
